Spyderco Massad Ayoob G10 Sprint Run
Hi All,
I just finished up another video overview and detailed written review. Thanks for checking it out!
[video=youtube;eeK7nto1uMs]http://www.youtube.com/watch?v=eeK7nto1uMs&feature=player_embedded[/video]
The Spyderco Massad Ayoob is another interesting knife from Spyderco that is (again) a little different from their staple offerings and although designed in the U.S. looks as though it could have had some foreign influence. It also vaguely reminds me of a less animated Ansø design.
So far the Japanese Spydercos that I have looked at have been the poorest in their manufacturing when compared to American made and the immaculately manufactured Taiwanese models. Unfortunately this knife is no exception; well that is partly true.
The outside of the knife was surprisingly well constructed. The edges, holes and back-spacer has been finished very nicely, at a much higher standard than say the Carbon Fiber Lum I reviewed (also made in Japan) which had chipping around every hole drilled.
The problem on this knife however isn’t as much cosmetic as it is mechanical. The mating surface between the liner and the blade tang is very poorly finished. This part of the knife looks as though it has been crudely ground on a low grit wheel and there doesn’t appear to be any bushings visible between the liners and the blade. The result is a grinding and marking on the tang that is obvious when the knife is both open and closed. Something that is questionable on a knife that is marketed a collectors item and demanding a higher premium than other models. This construction could also be a bit problematic if the knife gets dirty. The handle, liner and spacer are held together with rivets making a total breakdown and cleaning out of the question. Add some dirt to the rough liner surface and you could have some operational problems…
I find this a bit unfortunate as I really love the overall design of the knife. The forward leaning blade is well bellied and combined with the hollow grind is a born slasher. The narrow profile also lends itself well to thrust cutting. The grind has a short width and leaves a surprising amount of material toward the tip without compromising its sharpness. The high well jimped thumb ramp has a steep angle giving extra security and although blunt to the thumb is comfortable once the handle to blade angle is considered.
The handle itself is thicker and heavier than many other Spyderco’s due to the lock back mechanism and solid stainless back spacer giving it a good balanced feel. The handle is slightly over-sized and curved with light scalloping that provides excellent ergonomics. This knife can be held up at the forefinger groove or back farther for greater reach. The thumb ramp is effective in both positions. Aside the aforementioned grittiness in the pivot, the lock is smooth and has a comfortable amount of resistance. The lanyard hole is a functional diameter and the clip can be configured for left or right handed users, tip up only.
Over all I am satisfied with the Massad Ayoob as a design curiosity but would not recommend the knife beyond that. The rivet construction and finishing on both inner liners will very likely cause some problems for owners who want to subject this knife to daily use, especially tasks that involve grittiness. As a self defense knife, I’m not convinced that it could be as reliably deployed under stress as a model with a liner or compression lock (lock backs have more resistance when opening) coupled with a larger diameter thumb hole or an assisted opener. With that being said I believe the geometry, once the knife is open, would perform as claimed.
There are more pictures, specs and other knife reviews on my site if you are interested:
http://www.edgeobserver.com
Thanks for taking the time to read!
~EO
I have this knife on order. Before I did that I read a lot of reviews/forum postings about the previous run. This is the first time I've seen anything about the grindings and markings on the tang of the blade.
Maybe this is an aberration in the individual knife you reviewed and not a design flaw. I hope that's the case.
Thank-you for the review.
@Deviltooth
When it comes to their designs and engineering I think that Spyderco generally does a very good job. This issue is more of a quality control problem with Spyderco and their Japanese manufacturer. I find this a let down because many of their best designs, the Ayoob included in my opinion, are manufactured there. I think that any model a company puts out as a special edition should have stringent QC...
As for their Taiwanese manufactured knives, each and every one I have received has been absolutely perfect. It's likely due to cost effectiveness but I really wish that they would get all of their sprint runs and higher end folders made there.
Hopefully the knife you get is in top shape but from my past experience with the Japanese models it can be a gamble. With that said, it would be great if you could let us know how yours turns out.
Thanks for reading the review and commenting, I appreciate it!!
Eye of the beholder and all that jazz, but the Ayoob happens to be the ugliest (dis)grace of a knife that has darkened the knife community's doorstep in some time, and Jim Frost doesn't count. That said, it will keep orthopedics and rehabilitation practitioners in business for years to come, working out carpal tunnel syndromes, so anything good for the economy in these trying times must be looked upon quite favorably.
Thumbs up. Way up.
My example has none of the issues mentioned. I think you got a bad one.
Great review, Mas is a almost a legend in his field. His knives are designed for one purpose....deanimation or incapacitation.
I know Mas quite well, I sponsor him at my training company. gatorfarmtactical.com All of the handguns I've seen named for him have been very fine and virtually perfect works of art. I hope this knife is up to those standards.
Just really inconsistent quality control I suppose. At this price point I'd rather just appreciate my purchase rather than be concerned about getting a good one or not.
Thumbs up. Way up.
hmm, i think just the opposite when i look at the spyderco ayoob, i think its one of the most beautiful and wicked looking spydercos ever made.
I would have to tend to agree that the Ayoob is one of Spyderco's nicer offerings. Sometimes I sit on the fence a bit when it comes to designs that I'm not use to seeing. I wasn't sure about the Zulu when I first saw it but after buying and carrying the knife for some time it quickly became a favorite.
