- Aug 17, 2014
What scenario would it have to be for this lock to fail? Stabbed into a tree and then hanging off it?
Yeah, you know, #harduse kinda stuff.
Regardless of the apparent issue, for the majority of the people who carry their knives would't this issue be null to most given the situations in using their knife? What scenario would it have to be for this lock to fail? Stabbed into a tree and then hanging off it?
Because it comes down to the lock geometry, not the lock materials. When you change contact materials, your coefficient of friction between the two surfaces changes, and the angle of the tang might need to change as well. Steel or ceramic on steel would need a more shallow contact angle than titanium on steel, for example. Shiro and CRK do this correctly.Then tell me how shirogorov with the steel insert and crk with the ceramic ball lock face nailed it.(I’ve had the regular TI lock bar fail before on a small senebza no ceramic like the inkosi or umnum) Both knives would both break before the lock slipped. I’ve tried. Design flaw..End if story.
Getting the knife wedged in material during a heavy cut, then trying to pull it out. Or working in confined spaces and accidentally knocking the spine on something as you're moving around. Or doing a heavy piercing sort of cut with the tip in any fashion where the load on the tip is not directed towards the stop pin or blade pivot.What scenario would it have to be for this lock to fail? Stabbed into a tree and then hanging off it?
What are you doing in this video? Are you trying to close the blade while it's open? At first i thought your thumb was moving the lockbar.
****EDIT
I just tried mine. =(. It definitely shows the same symptoms of yours. I put some cut proof gloves on and tested a bunch of my frame lock knives. The Paysan has a very noticeable shift & Audible noise. You can watch the actual lock torque & move around, I won't go to the extent of spine whacking it though.
My Spydiechef also moves slightly, no audible noise and about 1/4 as bad as the Paysan...
Has anyone sent their Paysan in for warranty yet? I think I may and see if they can come up with anything. I've been meaning to send in one of my NIB PM2s (52100) that has hellacious lock stick when deploying, very loud click when unlocking it.
A good example of when this slip and can cut you pretty badly is, imagine slipping the blade under say a zip tie or nylon box strap spine against box or item zip tied and pulling up on the handle to cut the strap. Bam blade closes right on your fingers. I’ve had a lock fail on a small sebenza doing exactly that luckily didn’t get cut, and am very careful if I do that again. Another time using the back of the tip of a nirvana to scribe a line on a piece of wood and the light pressure caused the lock to fail.
****EDIT
My issue was his. Comment was why are people surprised by this. It shouldn’t slip if done correctly.Because it comes down to the lock geometry, not the lock materials. When you change contact materials, your coefficient of friction between the two surfaces changes, and the angle of the tang might need to change as well. Steel or ceramic on steel would need a more shallow contact angle than titanium on steel, for example. Shiro and CRK do this correctly.
I get that. I'm only elaborating on your comment, which is totally correct.My issue was his. Comment was why are people surprised by this. It shouldn’t slip if done correctly.
I can't believe people still act surprised that frame locks are susceptible to this. It's 2019 people! The list is loooong and well documented across production manufacturers, mid-techs, and customs.
As a lefty I've never been into frame locks anyway, but I never got their wild popularity or reputation as a "hard use" lock. For the most part, it seems like locks that fail even weak spine whack tests aren't much of an issue for people in everyday use though. Maybe that's why their dominance persists? I.e., the massive ZT threads where people were shocked, SHOCKED, and then ultimately didn't care lol.
Not trying to defend the Paysan in particular or say it shouldn't have better QC/tolerances/whatever, but at this point I'm not sure why people expect what they do from frame locks anymore.
Even perfect out-of-the-box specimins will wear over time. Lock stick... unacceptable. Steel inserts may actually make them even more prone to shifting/whack-failure. Late lockup is unacceptable. It developed up and down play. Etc...
GLTA
Yeah, I'll agree to part of it. Not mistaken on what I've owned though, as there is no mechanical difference between a frame lock and a liner lock, I said what I meant. I can see how the conclusion could be drawn though.GG:
I think that you're over-thinking this! In your second paragraph, you have the gist of it correctly apart from mistakenly referring to this type of lock as liner-lock, which you have then correctly stated in your last paragraph. This is was I was referring to:
"I've only owned a couple liner-locks, I don't particularly like them, so maybe this is just my lack of knowledge showing. Is it possible that the window between stick and slip is just too narrow with certain material combinations?"
IMO because utilizing this type of lock requires correcting the challenging geometry by whatever means necessary (well designed steel insert, ceramic detent ball, etc) Spyderco whiffed on this one specially when the blade is such a beefy chunk of S90V which from what I have also observed, is not necessarily ground that thinly either in the primary grind.
I really wanted to luv this pattern but the more that I read and find out about it, the more I become discouraged from being merely hesitant in ever owning one
Just to add another piece of information from just one user about just one Paysan in here. I got bored and decided what the hell, and so I took mine and did a bout a dozen hard spine whack tests just on my desktop this morning. No movement or failure on my example, everything felt as solid as I would expect.
Again, just one data point among many, for what it's worth. I'm liking the knife more and more.
I’ll be interested to see if lockup issues is actually only affecting a small number of the Paysans. When people pay that money for a knife with issues I can see them raising alot of noise and people being shocked by it.
If it’s really only a few knives with lockup issues then that is still regrettable but pretty common for there to be lemons in any knife model, especially on a newly introduced model.
How’s the detent on yours? Can you easily inertia shake the blade open?
Maybe this knife needs a titanium lock bar insert.
