- Dec 28, 2014
What size bit takes the pocket clip off to make it tip up carry?
Torx T6 should do it.
Yep. I would get a set of torx bits to make sure you are covered. Believe Home Depot has a Husky set in the $10 range. First thing I did was swap mine for tip up carry. Enjoy!Torx T6 should do it.
I'm so use to most knives taking an Allen key I didn't even think to try a torx...had a t-5 that worked thanks got it switched.Torx T6 should do it.
Just picked mine up! Any new PM2 is a "must have" IMO and the S110V makes a nice addition to the collection.
[/url][/IMG]
[/url][/IMG]
The color is only slightly translucent and it is definitely a very royal blue, almost purple.
Geesh that's crazy, you'd be better off skipping the line and getting one off the exchange, unless the secondary market has dried up....there were several last week for around $160.Ok, just put an order with KnifeWorks, nice lady on the phone told me approximately 250-300 people in front of me!!!!!!
Spyderco, I love you, please make sure you send what you have to KnifeWorks asap!
I forgot how much I like the Paramilitary. Such a good design.
I also forgot about the one thing I hate about it. The hideous shiny pocket clip.
I must replace this ASAP.
Anybody make a CF replacement for this? I found a few Ti deep riders for it, that might work.
I love the Spyderco wire clips. I wish there were wire clips for the Para....
This phallic, cheap looking, chrome shiny thing is really annoying me on this beautiful blue handle.....
with mine if I hit the strop long before it's "dull" it does work for maintaining the fine edge. I've cut more cardboard than the avg user by far with mine and hitting the strop ever 2 days has kept it shaving sharp. This steel is more wear resistant than s30v and when my s30v knives will only strop back to shaving sharp once or twice.Heat darken it like RobME did.
So after 2 full weeks of cutting up just about any cardboard I came across with my S110V PM2 (along with anything else that needed cut), it has finally lost its hair-popping edge. It was still sharp, but it could barely shave arm hair. I am actually pretty impressed, as this edge lasted longer under that kind of usage than anything else I've ever tried (including M390 and CPM M4; granted I have not yet had the pleasure of trying Cru-Wear or CTS-204P). This included a bunch of empty boxes that had accumulated and needed to be cut down for recycling (around a dozen roughly printer-paper sized boxes).
I figured a quick strop would bring it right back, but to my surprise, the strop (with green compound) essentially did nothing. That's a first in my experience, and shows some pretty high wear resistance. A half a dozen swipes on each side using the fine Sharpmaker rods at 30 degrees brought it back, and we'll see how long that lasts.
So far, so good! [emoji106]
How easy does s110v sharpen up on with powered equipment? I usually use the Ken onion wstk blade grinding attachment for maintaining and sharpening really dull or damaged knives. S30v does take a lil longer and a higher speed than say 1095cv but wasn't too bad. I was easily able to reprofile and set a micro bevel using the attachment on s30v, just wondering if it'll be noticeably longer with s110v. Don't wanna end up grinding it forever and risk over heating.You need CBN or diamonds to get the most out of high vanadium carbide steels like these, anything else just won't do.
When is that set to release?I can't wait for the M4. I love jade G10
