Just ordered one.
Been waiting for this to come out since the images of the proto surfaced.
I'm not a fan of the blue back spacer.
Maybe I can get a custom back spacer made though.
I love the look, just wish is was about $100 cheaper.
Just dye it.
The Technk has the same thickness behind the edge as thr Paramilitary 2. So initiating a cut wont feel harder than a P2, assuming it is sharp. The grind is also quite lean on such a beefy blade. Overal, eyeballing the blsde geometry, it isn't too far off from the Para 2's geometry. Basically this means, unless you are cutting fruit up or a few other mediums. The Techno will perform great.
If both the Para 2 and the Techno are true full flat grinds, the physics of angulation would say there is no possible way that a 4.5mm thick spine can be the same thickness behind the edge as a 3.5mm thick spine if the blades are the same depth (which they appear to be in the OP). If anything, the Techno looks to be less deep so I don't see how people can say that the blade is the same thickness behind the edge as the para2?
I'm not criticizing as I have a Techno en route but it's just not a logical observation unless the Techno is somewhat hollow ground.
The Techno could come down to the same thickness behind the edge using steeper angles on the grind. I never said the grinds were of the same geometry.
