- Jul 5, 2009
Hey guys. I have some info regarding Spyderco's VG-10 (Delica 3).
During the summer I work in landscaping which provides a great opportunity to test different blades. Today I had my Delica 3 with me. I keep this knife razor sharp which it was today. Sharp enough to push cut paper or shave with no pressure. The edge is not thin either. I keep the angle at 40 degrees inclusive with the Sharpmaker.
Today, I used it to cut nylon rope which is wrapped around trees to keep the branches tucked in during transportation. The nylon rope is not thick at all, nor is it new. There were about 25 trees plus an extra cut every once in a while so roughly 30 cuts on the nylon rope in total. Also during lunch, I whittled 3 or 4 sticks (twig size). By whittle I mean put sharp points on either end. That is IT. The blade wasn't used for anything else.
When I checked the blade at the end of the day, the entire edge was DULL. And I don't just mean it can't shave anymore. I mean it can't do ANYTHING anymore. I can run my fingers across the blade with A LOT of pressure. I can see the flat edge when I hold it in the light. The blade doesn't even come close to biting my fingernail.
To me, this is very surprising. In my opinion, today was not a rough/tough use of a knife. The cutting was very simple and very easy. For comparison, my Tenacious (with Cr13MoV steel) goes for DAYS without coming close to needing a sharpening. The Tenacious has been used for cutting stems, small branches, whittling, rope (same amount as the Delica cut today) and even slicing (not batoning) through .5-1'' thick (green) branches. (Yes, it can be done
Yes, it was just for fun
) After all of that I could still shave with it. Not exceptionally but it could still be done. Point being, it was no where NEAR dull.
So that was my experience with Spyderco's VG-10. Up until today, I had never used VG-10 for any real work besides opening a couple boxes and food prep.
I'm interested to hear what you guys have to say: If you've had the same experience; if you think what I did was tough work for the blade etc.
Time to start sharpening
Thanks for reading.
Thanks for reading.
