I bought an Olympic Foundry square wheel grinder from an estate last year, and while it's a great machine, I got two accessories with it that weren't really expected.
The first is this picture is a tight corner air bearing platten (or at least, that's the name I've given it, but could certainly be wrong). When this is installed, and connected to higher pressure air from my compressor, I can run a really tight corner across it. It's a pretty cool setup, even if I don't really use it.
The second accessory I haven't been able to figure out yet, and hope someone here has some ideas. I'm assuming that it's both of those parts, the arm/fiber wheel assembly, and then that idler wheel. It makes sense where the arm/wheel would replace the standard rest on my machine, but I'm not sure how the wheel is driven, nor how that idler wheel would attach/work.
Any ideas on that would be helpful. Thanks!
