- Mar 28, 2010
Hello any one can tell how to stabilize mammoth ivory
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Do you think this process also can be done only with dyed water epoxy which is a very thin resin and has a very long curing time and let it soak into the tusk by vacumizing? If so, it would be a much more easier process. The only issue is that the dyed epoxy maybe will color the ivory and give it a different color than ivory white..Ivory is stabilized with cyanoacrylic resins. The resins used to do wood are different.
The CA is a very thin formula that is drawn into the ivory under vacuum. It is cured with catalysts sometimes, and allowed to polymerize on its own other times.
You can stabilize scales that have been pre-shaped to the 220 grit stage by flooding them repeatedly with thin CA from a knife supply catalog, or from a woodworking supplier. After the CA has completely cured, sand the ivory to its final finish.
On mammoth that has a lot of cracks and splits, I first stabilize the material with thin CA. This may take a few weeks of sealing until no more will absorb. After the mammoth has cured, I fill the voids and splits with dyed epoxy resin.Sometimes I use a matching color, and other times I use a contrasting or darker color. This can make a piece of mammoth core that would be useless into a very interesting handle. Think or the handles made from filling cactus wood with resin...similar look.
Yes I know it´s an old thread and water epoxy didn´t exist at that time. Water epoxy is a very thin water based resin and by adding color it´s dyed.What exact resin are you calling "dyed water epoxy"? If it is a curing resin, then it should work.
BTW, this is a ten year old thread.
I thought that the mammoth is hard enough and did not require to be soaked with resin but the gaps need to be filled and glued. If that isn´t right and I need a super glue in order to soak the whole thing, which of these will be the best choice and for how long time does it need to be under vacuum?It doesnt work. This is why the differences between an epocy or phenolic resin vs the acrylic monomers in stabilizing resin are important. So many people think they can soak wood in epoxy and make super stabilized wood.
The resin has to flow through the pores of the wood. In commercial stabilizing, this is very easy because the presence of solvent means the entire resin monomer is disolved and acts as a liquid, being wicked through the pores by capilary action before the heat cures the resin in place.
Epoxy is a very thick, viscous liquid that would cure rapidly in an ultra thin pore, stopping up the pores and preventing anything but the most minor uptake. Thats why epoxy cured or phenolic products like micarta or pakkawood are always made in layers, because a full layer of resin can be applied sperating each layer of medium.
Do you know about any affordable thin CA which can be used for this purpose, and will it be advisable to soak the pieces of mammoth in this glue in the same way as with cactus juice and get it under vacuum, or will the CA harden under the process?Mammoth is much like wood. It comes in many hardnesses and densities, and a variety of states of decay. Stabilization for walnut burl may be quite different from a piece of punky spalted maple or a slab of balsa soft Buckeye burl.
The mammoth ivory for knives most of us are familiar with is similar to elephant tusk ivory (enamel) and is dense and nearly impervious to absorption of any resin. It is hard to dye because it is so dense. It does not need stabilization, but may have cracks on the surface or in the material that need to be filled. Thin to thick CA works here.
Then you have the opposite end of the spectrum with tusks hath have been leeched in water (dredged tusks from the North Sea are common and cheap). They are usually quite chalky and punky. These have to be stabilized to be usable. Thin CA is the best resin for the job.
Also, there is the core material, which was more porous to start with. It is often chalky and/or soft. Thin CA works best here.
Finally, you have weathered tusk pieces which are splitting along the growth rings and cracked apart in places. They look like delaminating plywood. These can be used sometimes if you first harden/stabilize the material with a thin CA and then fill the spaces with a thicker and hard resin (usually dyed to contrast).
OK!To flood stabilize ivory, I put the piece in a disposable small plastic container and pour some resin over the piece, maybe 1/2 an ounce. Turn the piece with chopsticks often and tilt the tub to get the piece fully wet. You may have to do this for a good while. Set the tub down with the bottom tilted so the resin runs to one side and put the ivory on that side so it sits in the excess as much as possible. Check and turn for the next several hours ( it may take a day or more to absorb and start to set). Once it has soaked in, or the resin is getting thick and geled, take the ivory out and set on a sheet of saran wrap.
OK!
I understand but is this the only way to do it, or can I also do this in a vacuum chamber in order to have the glue penetrating faster? And do you think it can be cured faster after this process by warming it up in a stove with a glass of water inside which will create hot vapor?
