Starfire Swords
Skrapmetal
Anyone know what type of steel they use? I know it's high carbon, but that's all I can find.
I've had a scimitar for quite a while, and I'm planning to put it to a belt sander and grind a good edge on it. I know they aren't technically made for combat, so the heat treat probably isn't very good for edge retention, but honestly I don't see myself getting into many sword fights with it. I just want it sharpened for my own sake.
The geometry isn't made for cutting.
They make swords for theatrical use, not cutting practices.
If you want a sword for cutting, even only light cutting, then get a sword that's not built like a crowbar.
I'd agree with HolyRoller.
A friend of mine bought one of their daggers, which I edged. It took a long time, as the geometry really is not correct for this sort of thing. Ultimately, you could cut food with it, but that's about it. (Their site specifically comments against sharpening. http://www.starfireswords.com/info/home.php)
If you've owned a scimitar from them, the following is not news to you:
They're great for theatrical work..as long as the actions are neither quick nor complex. I have a few of their pieces, and overbuilt is one way to describe them. Balance on the shorter pieces is fair, but the longer models are hefty (they are not distal tapered, and you can feel that in the balance). Their Templar sword looks like it has potential, however.
For what it's worth, Starfire Swords seem to be the manufacturer of choice for the jousting folks at the King Richard's Faire south of Boston. In that setting they are pretty much unbreakable.
