I use a coal forge but I think the same would apply to charcoal (I'm extrapolating here, but I shouldn't be too far off).
I use a small squirrel cage fan from a central heating system (the fan to feed the burner, not one for distributing hot air through the house). Works perfectly.
I start up my fire by putting a layer of ~ 1-2" of used coal (=coke) in the firepot. I think you can start with fresh charcoal since that doesn't have any bituminous content that first needs to burn off, and charcoal catches really easily. I place a fire lighter cube (the compressed wood fiber kind, I hate the white chemical ones, smell bad!!) on top and light it. I take a piece of ~5", long fiber wood (pine, birch, whatever), about 1" in cross section (they sell those as long chips to start your fireplace) and put it on my anvil. I then hammer on the side to break up the fibers so that I end up with ~1/8" thick, long splinters. I break those in two without separating the halves. I can then use them to build a tipi over the fire starter. When they start catching fire I start the fan with the choke slightly open. I then start carefully raking some coal against the fire, open the choke a bit more, rake some more coal etc until the fire is burning hot and is covered with coal. I poke a few holes in the coal blanket to allow a few jets to escape which in turn light the gaseous smoke coming from the coal. Wait a couple of minutes and I'm done. Well, to get a really nice working fire with coal takes a bit longer after that, but with charcoal this should be about it...
Cheers rOdy
