Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Wasn’t sure if I was using the correct terminology.A blank is already profiled. Pretty sure JT sells blanks and can heat treat them for you too if you want to grind post heat treat. If you want to cut out the shape you want then you just need a piece of bar stock. Aldo (New Jersey Steel Baron) has some A2 bar stock as does Alpha Knife Supply. Both great vendors.
Thank you.Welcome to Shop Talk. Fill out your profile so we know where you live and a bit about you. This helps us give better answers.
Most all knifemaking suppliers carry A2. It is a fine steel and makes a great knife. There are many other steels to use, too. Tell us a bit about how you are going to make the knife and how the Heat Treatment will be done and we may be able to guide you better.
