So I know this is an old thread, but I actually have an update to the testing! I was talking to Des Horn at the Canadian Knifemakers Guild Show the other day, and he was saying how much he liked RWL34 and recommended that I try it or something similar like CPM154.
That made want want to go back and have a look at the results of the testing that I did all those months ago. When I was looking I noticed something... The steel that actually fared the best in the impact toughness test was CPM154.
That got me thinking. If that steel did so well in impact toughness why was it behind the other steels in the final results? The reason was because it 'failed' the tip strength test. If it had passed the tip strength test then it would have been 3rd overall in points rather than 5th, with the difference between the top 3 being nothing other than minor.
Luckily, after I completed the testing 'way back when' I decided I would label and keep all the broken parts in case I had a future use for them. So I went and dug them all out to see what the tip thickness was like on the CPM154 sample compared to the other blades, something I probably should have looked at in the past!
Here's the results:
Turns out that CPM154 likely failed the tip strength test simply because the tip of that test blade was a fair bit thinner than the other test blades! (27% thinner)
I grabbed a couple of the test blades and re-did parts of the impact testing, and it's really not a fluke. I wailed on the edge of the 2 CPM154 test blades with my trusty 'testing crowbar' and they held up really well. Every bit as well as the CPM3V test blade and the A2 test blade.
It seems I might have discounted CPM154 without good reason, so I'll be making a few test blades in it over the next few weeks to see how they hold up to some further testing.
Just wanted to make sure that people got the update!
-A
