While we're at it. I have had limited success sharpening the blade on a strip of leather laden with tripoli compound. Figured maybe I did not put enough compound on the "Mini Strop" I made or else the makeshift strop is too small. Just wanted something to drop in my backpack. I Mounted a small piece of vegetable tanned leather on a block of wood. One side with tripoli, the other with chromium oxide. Got any ideas?
Maybe one day if yall ever come to bama for one of those darned wonderful conventions, I'll get the chance to see Yvsa' sharpening techniques
Yvsa, do you use the edgepro prefessional in your demo? [/B]
KK I have about 3 sets of different crock sticks that I sometimes use to touch a blade up with, but other than that all my knive's are sharpened freehand.
There's really nothing to my technique that anyone can't master.
Getting a convex edge is a natural movement of your hands and wrists while sharpeining IMO.
The Biggest Secret or Trick is to Get a Burr ALL Along one side of the blade First and then do the Exact Same Thing on the other side and that's it, simple really.
Then you take the burr off by honing with progressivly finer hones on each side and then finish with the strop.
KK try laying the khukuri down flat and pushing the strop Away from you at the desired angle and see if that doesn't improve your results.
And if it doesn't try it first with the hones and then the strops. I'm betting it will help you.
All the talk about exact angles and even bevels is just so much talk to me. I don't particularly care what an edge looks like so much as I do if it works or not.
If one is attempting an experiment like Cliff with the silk then. yes, the angles and such become very important, but not so for the average guy in the field.
Just remember to get a burr all along one edge first and then the other. If you don't have to obtuse an angle the knife will cut.
I made metal deburr knives from 3 cornered files, hollow ground on all three sides and then put on a Norton India Fine Hone.
That's an included angle of 240 degrees and it would shave hair readily.
I would have to tape up half the blade to keep from cutting myself when using the knives.
