- Jan 25, 2006
If I put a step pulley on my motor, driving a single pulley on a shaft between two Pillow blocks. Why can't I allow the shaft pulley to slide or float on the shaft to be parallel to the step pulley? Would the tension move the pulley to be in line?
Going to use a hinged motor mount to manage belt length differences.
If that is a bad idea, can I run my three step pulley to a two groove 2 inch pulley? Will the small offset be a problem? Talking about 1.5hp 1725rpm driving a belt grinder and disc mounted opposite ends of the shaft. I suppose I could add another 2 inch pulley beside my 2 groove for straight belt runs.
