Never done it but I think you would want to remove the bead blast first. To me the scratches from the stone wash are finer in nature. Guess you could just try it as is and see what happens and if its not the effect you want then sand and rewash.
Rick Hinderer calls that a "working finish". They bead blast the blade and then stone wash it for a matte version of a stone wash. Not sure how that would turn out on titanium, but here's how it looks on the CPM S35VN of the FieldTac 5.5
Nicely done! Looks so much better with a Sebbie clip, I imagine it's better in hand than the original.
How did you stonewash it? Do you have an abrasive media tumbler or did you use the gatorade bottle in the dryer trick?
I went ahead and stonewashed it with the finish on first. Didn't like the results - too much gray left in the finish. Sanded the clip down with a 320 grit sand sponge and then stonewashed it again. Insanely happy and impressed with the results. Matches the finish almost perfectly. Check it out.
Thanks for the info! Have you ever tried this with steel or aluminum parts?
Sent from my Nexus 5X using Tapatalk
Man that looks great! On a side note, how do you like the Ti-lock?
