Hi guys!
Well here is the thing, my brother ( a doctor) is a volunteer with a our local Urban Rescue Team and the other night he was telling me about this accident they responded to, in which one guy had some kind of injury in the ankle area but he was wearing safety boots, so in order to help him, they needed to cut the boot without causing more damage.
He carries a Gerber Hinderer Rescue , so he deployed the seat belt cutter to go through the boot, but the cutter was too thin and didn't fit, he says he tried to use the resuce blade on his knife and even the blade of his buddiy's Victorinox Rescue Tool (which has a better angle) but the back and forth movement would hurt their patient. They ended up using those weird scissors all EMTs carry, but I took them quite a while to go through the whole boot.
The point is, when he told me this, I figure I'd get him for his b'day either a strap cutter or gut hook to use in those situations.
I've kind of narrowed it down to the following (price point and availability are almost the same, so that is no and issue)
1) The new Gerber Strap Cutter. It has a wide cutting area, a glass breaker at the end (which is a great puls) and a nice MOLLE-compatible sheath. The downside: 420HC, probably made in China (I've had awful experiences with Chinese-made Gerbers)
2) The Benchamade Model 5. The cutting area is also very good, 440C steel, US-made, Benchmade quality, the sheath is OK but there is no Glass Punch which is kind of desirable.
3) CRKT Extrik-8r. Looks fine, plastic sheath, has a screwdriver tip at the end which I guess could be used as a glass punch. Chinese-made but there is no info on the steel.
4) Buck/ TOPS strap cutter. I don't like the sheath but the tool is nice, US- made, Buck's 420 HC, again, no glass punch. BTW, I also like the traditional Buck Gut Hook.
I discarded the Benchmade Houdini Pro and the CRKT Exitool because of the LED light, since my brother usually works under the rain or around water.
So my questions,
Has anyone used the Gerber Strap Cutter? I'd be perfect for me but I'm concerned about quality.
Do you think I could use either the screwdriver on the Extrik-8r or the back of the Benchmade/Buck as a glass punch (given the case)? Are they strong enough?
Thanks guys.
So my questions,
Thanks guys.
