I have a Strider HT-T, the small/medium sized fixed blade with a tanto styled blade. The main portion of the blade is quite sharp and cuts well enough, but the tip portion barely has an edge, it's almost blunt. I want to put a different edge on the knife so that it cuts better. I don't have very high expectations, but the knife as it is is a very poor cutter.
I've seen pictures, here, by Kwakster of the awesome job he did reprofiling his Strider DB. I believe that he used a combination of an electric grinder and a Wicked Edge. I have a Wicked Edge sharpening system with diamond/stones from 50 to 1000 grit, what would you guys recommend that I do? The HT-T currently works fine for opening crates and heavy duty packaging, and has done well with zero damage to the [non-existent] edge.
I understand that these knives are designed, literally, as sharpened prybars, I'm just trying to see what the design is capable of when some attention is invested in the cutting edge.
