Kizer has many series (names) of knives.
Which series is has the best quality? I like overbuilt stuff
I don't think any of it is over built. You may want to look elsewhere if you want over built. None of the Kizers I've had were over built to any degree. I also don't see them as high quality but budget knives with good materials. Not bad knives but not high end. Most of the screws they use are soft and under sized. Yet to see a over built pivot at the least.Kizer has many series (names) of knives.
Just a tip, disengage the lock if your going to baton with a frame lock. It will help not break it and it will work all the same, assuming the stainless doesn't fracture from high hrc.While I haven't done this test with other Kizer knives, I pounded this Kizer Bolt through a hardwood log with a 1.25 kilo sledge hammer.
It runs on washers so no bearings to damage. The only damage to the knife was a bit of the finish on the blade came off. It's now well used and I can open it as fast as most flippers.
Here's part of the video.
