The best technique I've found is one I lifted from Cape Forge knives back in 96'. Mike explained that a good honing leather is only good for one thing - Making a good edge great,
It won't make a bad edge good, and it's very easy to dub and dull a good edge with any leather.
The technique is simple. Lay the blade flat on the leather and push forward while raising the spine in tiny increments. At some point the edge will bite into the leather - that's the angle that you have no choice but to work with because it happens to be the actual angle of the edge.
Once the edge bites pull back with light pressure and at the end of the stroke just stop - stop and pull the blade up and off the leather.
If you pull the blade off of the leather at the end of the stroke in an arc, which is a very normal thing to do, you will have undone all of your work.
Once you experience the level of perfection that leather honing can provide and have a leather honing epiphany you will probably seek better leathers to work with.
You don't need compound on a good honing leather. The technique works with other things too, balsa, etc - even stones and fine papers.
This is a good muscle memory technique - hope it helps.
Keith
Great original post. I think this ought to become a sticky.
Motion seconded.....
All in favor, say AYE..
I live to serve
excellent info, mostly i use a strop to eliminate possible burrs since i probably have every sharpening aid known to god. one problem i've noticed with real keen smooth edges is the lack of bite on some of our local trees , mesquite & bois d'arc. super smooth edges [for myself] do'nt seem to make much progress trying to cut into local superwoods. maybe i just thought i had a good edge but extensive use on the edge pro to 6000 polish tape then a few strokes on the stroup & i ca'nt make decent bites into bodark. at this time i have been using fine spydie hone after mirror polishing the bevels, seems to bite better in hard wood but maybe i'm fooling myself. ---dennis
if i want go from gold to green to red compound, should i have a separate strop for each one.
I heard the word strop and I wondered what it was. Now I know, great thread. Ok here is my question. I use a stone to sharpen my edc which is a Kershaw Blur. I spend 5-10 minutes a month doing this. Would stropping be more effective? And what is needed to strop? I have a raw leather belt, would that work? Or do I need compounds and... stuff?
