I would not try this with a dimond saw or grinding wheel!
Those things are desiged for higher hardness material that doesn't burn...
My guess would be that if you try with the grinding wheel, you'd be lucky if you end up with someting Taliwhacker size...
The saw... make sure that you wear at least a fully enclosed bike helmet...
Elof, I appreciate your concern my friend! However, these aren't your standard, run-of-the-mill garage tools I'm talking about using here. They're NOT a giant chop saw and a bench grinder running at 10,000,000 RPM, lol...
Note, earlier I said these were
wet tools. The saw is like a tile saw on steroids. It's a flooded table (probably holds around 15 gallons of water, depending on the size of the work piece) and the
thin saw blade is constantly flooded with water where it's not submerged. It's used for cleanly and precisely cutting all sorts of materials. I've used it for steel and aluminum bar stock and angle, carbon and glass composites, tile, and glass. It can cut materials up to 4" thick, and 24" long. It would handle this job with ease...
The grinding wheel was originally made for the optical industry. The wheel is ~14" in diameter, ~2" wide, and mostly made of some kind of a bronze alloy. The outer ~3/16" is solid bonded diamond, approximately 600 grit. The wheel sits in a ~5-gallon water trough almost halfway submerged, and its speed is fully adjustable from a crawl up to about 600 RPM. Much faster than that and water is going everywhere.
The saw cuts somewhat automatically once you have it set up. The wheel is fully manual. PPE should be worn, but maybe not quite to the level you mentioned.
