Superknife II: Long Term EDC Review
Harry Callahan
Fresh outta warranty
The exact date escapes me but somewhere over two years ago I embarked on a mission to put a Superknife II razor knife through a long term EDC test. A little background first...
As we all know, there's not a real "quality" superknife style knife on the market. Oh sure, there's been whispers of Spyderco coming out with one eventually but overall we're stuck with Taiwan made, blister-packed crapola from the aisles of Lowe's and Home Depot. I had a couple of those clunkers and quickly realized they were trashbin bound. After some research here on the forums, it became clear that the best option for one of these knives was to go with the "original" Superknife. The actual patented brand-name original.
Knowing what kind of junk this style of knife often is, I opted to order mine from AG Russell. That way, if it fell apart (like the Lowe's and Home Depot crap) at least I'd have AG's excellent warranty to fall back on. Sure, we're only talking 20 bucks here, but it's the principle. I'd been burned on these knives before.
Upon first inspection the day the package arrived I was unimpressed. The linerlock slipped back and forth on the tang resulting in some slight blade play. I'd have to be careful and keep that in mind. A potential lock failure with a razor knife isn't a pleasant thought. I was also disappointed in the pocket clip's grip on my jeans. It seemed to slip easily instead of bite like my Spydies. But I was determined to see this through. I wanted an interchangable razor knife and if there wasn't a quality one available, then this 'un would have to do.
Under daily useage it became clear that the warncliff style blade is ultra handy. Man, you can slip that tip under the strongest nylon cable tie and SNAP!! she's cut. Gotta love that. I also quickly found out that Irwin blades are the best. They flex but do NOT break. A few swipes down the white sharpmaker stones and they get seriously sharp all over again. Quarter skinning a grapefruit creates a patina as these blades are carbon steel. Another wonderful aspect of these superknives is when you need to scrape a gasket, the blade just comes right out, no tools required, and you've got a gasket scraper. Very handy.
The open back design is great for cleaning. You can hose this thing down with brake cleaner and use compressed air or tap water to clean it. Nice. The Lowe's model was closed in the back and a pain to clean. As time went on I became accustomed to the less agressive grip the clip had on my pocket seam. It stays put even though it FEELS loose. I guess it has a deep enough hold. Makes it easy to draw from the pocket and get on with the business at hand.
I have a couple of compaints naturally. These problems could be addressed quite simply. Number one, the screws keep coming loose. No amount of loctite seems to help. The pivot screw works loose, the tiny pocket clip "stabilizer" screw. The tiny screw that holds the "roundel" (thumbstud) in place. It is a problem. Number two, the linerlock slips on the tang. I want to stress, however, that I've never had a lock failure and I've never been able to induce one. The lock simply slips so far, then stops. I don't know if the tang needs to be more radiused or what.
Overall, this little knife has more going for it than it has going against it. I've been using this one for savage cutting tasks daily for over two years. I have a spare, ready to go at a moment's notice because I wouldn't want to wait a week for a replacement. That's how much this little workhorse has grown on me. I only carry this knife for work. When I'm dressed casually and relaxin', naturally I have something more upscale clipped to my pocket. After all, I'm a knife snob. :D
This style of knife screams out for a heavy hitter like Spyderco or Benchmade to produce one. A high end superknife would fill a gaping hole in the industry. Until then, the original will have to do. And two years of daily hard use tells me that she does all right.
Can anyone tell me how to resize a pic to make it "attachment friendly". I can't upload the pics I've taken of this Superknife because they're too big. Very frustrating. I'm using iPhoto. Any ideas?
I upload my pics that I want to post to photobucket. Once uploaded, I get the option to resize the pic.
Try the Tenacious or the Persistence. :D
Can't take the blade out, but liner lock + 4 way clip with G-10 handles makes it a pretty nice knife for $30.
Okay, here goes. Thanks for the Photobucket suggestion. Took a while to open an account and get the pics uploaded but here they are...
Ergonomically this knife is a sawmill two-by-four. Sort of the Al Gore of handle ergos. Also, the "roundel" thumbstud is kinda difficult to get accustomed to after using the Spyderhole for so long. Neat idea, however, as it is part of the "tool-free" blade changing system.
Cutting performance is, simply put, awesome. This thing doesn't spread cream cheese or peanut butter worth a hoot, but it cuts like a laser. Not much more can be said on this as we've all used these contractor blades before and pretty much know how good they cut. As mentioned in my original post, the sharpmaker is an excellent way to maintain these blades. Not only does this cut way down on the need to replace the blades as often, it also results in a sharper-than-factory contractor blade. Keeps my sharpmaker skills up to speed also. I've really learned my way around that thing. No more rounded off tips.
So after a couple of years daily carry and use, I have no plans to shelf the SKII. In fact, it would be impossible to imagine getting dressed for work without the thing clipped to my pocket. It's ugly, cheaply made, and it handles like one of those clunky 1960's era chainsaws. But it cuts. It works. It doesn't try to be something it can't be. A fine product that's well worth a serious look. Give one a try. For the money, there's just no way you can go wrong.
The SK2 is probably the best I've come across in that type of folding utility knife. The low ride pocketclip is highly appreciated. I also have had the pocketclip screw come loose, but it's never actually fallen out somehow. These are available now for under $5 in red and blue it seems.
I have had bad luck with Irwin blades, though.
You might also want to try the Lenox bimetal utility knife blades. They were the first to make those and all their blades are very good, I include hacksaw, Sawzall, holesaw, and bandsaw blades in that statement. They are much sharper when new than the Stanley blades. I have no experience with Irwin's bimetal blades.
My own tastes run to a good retractable utility knife. The handle ergos are better, the blade stickout is adjustable, and numerous spares fit inside the handle. The good ones are all tool-free to change blades/access spares. They are bulkier, but the ergonomics are worth it to me, and they are much safer for heavy cutting than the folding kind, IMO.
Bill
I'll have to try out Lenox. One blade I'm liking is this unusual serrated kind that's sold at Lowes. It's unusual in that the serrations are separated far enough from each other that the pattern is more like "flat/serration/flat".
Yeah, if you're going to be using a utility knife for an extended period of time, perhaps as part of your job, the generic retractable (or fixed) Stanley knife is probably a better choice. Stanley has a recent model out, model 10-016, that is a slightly more pocketable version of the old ubiquitous Model 99, being about an inch shorter and about the same thickness as a Spyderco Native. American made OTF knife for about $2! ;) How can yo beat that?
As new:
Modded for easy pocket carry:
Shecky,
I like the clip added to the Stanley knife. Are you sure it is USA made? Lots of Stanley stuff is now made in China. Not that there is anything inherently wrong with that, just something to look out for.
The bimetal blade can be bent into a U without shattering, although the harder edge metal will crack back to the laser weld. The old type are very brittle and snap off easily. Bimetal blades also hold an edge much longer in abrasive materials like drywall. I gave one to a drywaller friend on a job and he was blown away by the fact of how many regular blades it outlasted.
My favorite utility knife is no longer sold. It is the blue Lenox handle with retractable blade, tool-free blade change and spare access, made in Spain. Spring loaded ball bearings press against the blade to eliminate lateral wiggle. At 7-5/8" with the blade retracted, this is a big handle, but the quality and ergonomics make it my favorite hard user. The new white ones are also good, but have more lateral play in the blade.
I agree that the Stanley 99 is ubiquitous, even iconic, like the Buck 110 in folders.
Bill
I always wanted to get one of those SuperKnives. Everyone I've handled felt like junk though. I too wish somebody would step up to the plate and make a high quality version. Maybe send one in to STR for a framelock conversion?
Shecky,
The opposite side of the hang packaging has a small graphic declaring:
Made In USA
with global materials
I figure that counts. :o
I'll have to find some Lenox blades to try. I did buy a package of Irwin bimetal blades, but they couldn't hold an edge for crap. They might have been a bad batch. But I was really not impressed. Perhaps they forgot to make them bimetal, and used the soft steel for the whole thing?
Sounds interesting. There certainly lots of utility knives on the market.Most seem to be simply variations on the Stanley 99, but there are a few useful variations with innovative features, such as those ball bearings.
