I started building a surface grinding attachment and thought I would document my progress as I go along. This build is likely going to take a little while, as I have not really made a plan or ordered any components other than the linear rail.
My first step was to make the chuck. I am not sure if anybody here has made one out of steel before, but I don't recall seeing anybody post about it in the Home Built SGA thread. In case anybody wants to attempt this on a mini mill, I'll add a bunch of details here describing how I machined the chuck. I started with a piece of 2.5" wide by 1" thick cold rolled mild steel about 12.5" long and immediately ran into trouble. I wanted to mill the width down to 60mm to match the length of the magnets and reduce the thickness by 2-3mm to lose some weight. I first tried using a 2.5" face mill for this, but my mini mill (PM-30MV) was not able to take a decent bite out of the material without excessive vibration. After switching to a 5/8" end mill, things improved a lot and I was able to get the piece machined to 60mm by 23mm by 316mm in less than an hour. The length of 316mm was chosen because it was the closest even number.
I am using 10x5x60mm magnets and decided to use 19 of them with 6mm space in between them, and 9mm left over on each end. After some quick back-of-the envelope calculation, I figured milling 19 slots 7.5mm deep and a bit over 10mm wide is way too much hand cranking, so I looked for a way to align the slots with the x-axis, which thankfully has a power feed on my mill. My vise came with a rotation base that has been collecting dust since the day I got it, so I cleaned that up and used it to rotate the vise ninety degrees and then indicated the fixed jaw with the y-axis. I milled the first 11 slots yesterday and used a 3/8" carbide 4-flute end mill at 2,800rpm with a mist coolant system. I did the first slot by hand to get a feel for the depth-of-cut the mini mill could tolerate. While I could get a 1mm depth-of-cut without any sign of trouble, I decided to only take 0.75mm per pass. I guess @J. Keeton's video where he fried his mill machining a magnetic chuck was stuck in my mind... To get to the 7.5mm depth I needed 10 passes, plus two passes to widen the slot to a bit over 10mm, so a total of 12 passes per slot. Since I do not have enough travel on the y-axis, I had to flip the part after the first 11 slots to machine the remaining 8 slots, which I did today. To align the slots with the ones I machined yesterday, I briefly looked at the edge finder and then just put the cutter in the last slot, moved the y-axis until it touched the edge of the end mill and zeroed out the DRO. On the first pass, I added 0.1mm to the offset and then measured the ligament to make sure it was 0.1mm larger than that of the other slots, just in case I needed to make an adjustment. There was a small difference (0.02mm), but I didn't trust the calipers enough to bother making an adjustment on the DRO. The total time spent machining the slots was 75 minutes yesterday for 11 slots, and 45 minutes today for the remaining 8, not including setup and cleanup.
After some deburring, I made sure the magnets fit in all the slots. They fit very nicely and I am very happy with the result. Without the magnets, the chuck weighs about 6.5 pounds, so it's probably around 4 pounds heavier than an aluminum chuck of the same dimensions. I think the chuck is probably a bit thicker than it needs to be.
I want to build the translation stage for the feed adjust next. I am thinking about something similar to the one K Ken H> built and described here, but maybe with a dovetail. It's probably time to make some sketches and figure out what type of wheel to order. Based on
REK Knives
's comments, I'm leaning towards a metal wheel, maybe a 5" tracking wheel turned to remove the crown.
