- Mar 13, 2006
LOL We need more Skivas out there. Between me and Phillip we're holding down this thread [emoji6]
one shipped put today
hopefully they will join in
ive smoked a bunch of pork butts w/ awesome results if I do say so myself. the brisket scares me. first the price and the fact i might screw it up
Dont be scared of brisket its not that hard just do not over think it!
Where can i get a osage Skiva???
There's a young guy in Austin , Aaron Franklin. He's the current king of BBQ brisket these days. He learned from the old guys around here. Got some real good YouTube videos. You might check them out.
im familiar with him. i've seen many shows regarding his restaurant and his techniques. "BBQ w/ Franklin" was one of my favorites.
Here is Allens latest un-named entry into the kitchen knife arena.
I am not good at reviews so I'm just going to post basic stats and post some pics.
The knife bit DEEP into the pit and I did not feel like I could remove it safely w/o cutting myself. It was slippery from the oils.
I chopped right through it. I would NOT recommend this.
First, fantastic knife and post!
Second, the trick to removing the pit from the knife:
Put the spine of the knife between the thumb and first finger. The spine is pointing to the web between fingers. Similar to your pinch grip when cutting.
Next, put your thumb and first finger about half way on the pit and half on the blade steel.
Now pinch. The pit is slippery, so your fingers, as they are pinched together, will push the pit off the blade. You don't come anywhere near the cutty bits of the blade. You don't risk chopping your fingers off by trying to cut through the pit and it is quick, easy and safe.
I'm not sure if you've ever launched a folded bottle cap at a buddy by pinching it, but it's a similar process.
Great post and pics Phillip.
I prefer the chop and twist method for removing avocado pits. After you cut half of the avocado and pull it away from the intact pit. You just chop 1/4 to 1/2 into the pit in the other avocado half (not through it) and then turn the knife like the hands on a clock. The pits comes out clean, still attached to the blade. Then use a spoon to scoop the inside of the avocado (as a whole) away from skin. Then do what you'd like with the cleanly separated avocado halves.
Also, here's a shameless plug for both Fiddleback Outpost and WA Surls. We have a few kitchen blades from Allen remaining on the site.
FiddlebackOutpost.com/collections/wasurls
Thanks, I'll give it a try next time.Here is Allens latest un-named entry into the kitchen knife arena.
That's the method I use. icould not get a good grip on the seed, so I slammed it into the cutting board and the knife went right through.I prefer the chop and twist method for removing avocado pits. After you cut half of the avocado and pull it away from the intact pit. You just chop 1/4 to 1/2 into the pit in the other avocado half (not through it) and then turn the knife like the hands on a clock. The pits comes out clean, still attached to the blade. Then use a spoon to scoop the inside of the avocado (as a whole) away from skin. Then do what you'd like with the cleanly separated avocado halves.
thanks Tony
I think it should definitely be on the menu at the next Trackrock
