chiral.grolim
Universal Kydex Sheath Extension
- Dec 2, 2008
Survive! GSO-2.7 (pass-around)
This knife came to me as part of a pass-around initiated by grogimus:
http://surviveknives.com/gso-2-7/
Specifications:
Blade length: 2.83" tip to handle (average, is actually shorter at spine, longer at belly due to slant of guard)
Cutting Edge Length: 2.7"
Blade Width: 1"
Stock Thickness: 0.125"
Bevel geometry: ' primary, 20-dps secondary, 0.020" BTE
Handle Length: 3.75" + 0.125" pommel
Handle width x thickness: 1" x 13/16" swell (3.1" circumference), tapering in at the index and belwo the swell
Over all length: 6.71"
Weight: 3.6 oz bare, 5.8 oz with sheath
Blade Material: CPM-20CV, 60Rc
Handle Material: G10 or Micarta (linen and canvas available)
The GSO-2.7 is not the smallest knife in the Survive! line-up, but is an alternative to the Necker II for users that prefer a straighter handle without the ring and a drop-point blade. It seems to have been designed as a smaller version of the GSO-3.5 which was itself a smaller version of the GSO-4.1.
It is comparable in blade and overall length to knives like the ESEE Izula, Buck Paklite 140, White River Backpacker, and others.
The blade is a full 1/8" thick at the spine. The 1" blade width features a 0.64" primary bevel that tapers to 0.56" for a stout drop-point tip more akin to the Buck Paklite than the finer-bladed Izula or Backpacker, suggesting capacity for rougher use.
The 0.020" BET is stout enough for some serious abuse, as will be shown, but still places it above thicker-edged knives like the Izula (0.030 from the factory)
This GSO-2.7 features black G10 scales with a "microtexture" finish. The finish, which is machined as a regular pattern of tiny divots in the surface, improve grip in wet/slick conditions. The difference is VERY noticeable in hand.
The scales have 3D countouring very similar to the previous (2015) versions of the GSO-4.1 and 3.5. The spine of the handle is very straight, with grooves along the belly ideally suited for a hand ~3" across (size small). My hand (Medium 7-7.5, ~3.5" across) can just squeeze into this space, but the lateral flare of the scales for the last 5/8" makes it feel smaller.
Laterally, the "neck" tapers in from the 0.81"-thick palm-swell, and flares out at the pommel, giving a coke-bottle shape. For my hand-size, that pommel flare is obnoxious as it japs into my hypothenar muscle-group in a variety of grips. If I were to purchase one of these knives, I'd likely grind away that flare to better accommodate the size of my hand. Larger handed individuals might not notice the flare or might find it more annoying. *shrug*
Those thick scales do, however, provide a great deal more comfort to the knife is use, accommodating signficant pressure from the hand over the 3.1" circumference, compared to the cord-wrap or bare metal of the neck-knives comapred here. Doing heavy cutting, each pressed hard into my hand, enough to create hot-spots very quickly, while the thick-scaled knife transfered the power straight into the cutting material :thumbup:
The Izula is actually offered with a longer handle in the Izula II and scales can be purchased from ESEE or a dealer or a customer maker - I have not used them so cannot comment on how they would compare. https://www.theknifeconnection.net/esee-izula-scales/
Similarly, the Backpacker is offered in a scaled-version called the 'Caper': http://www.whiteriverknives.com/collections/knives/products/caper-na
I have not found scales for the Buck 140 but hope that Buck offers something like this in the future (unlikely).
The benefit to the cord-wrap is a MUCH lighter knife, slimmer profile, and no pommel-flare. For a backpacker or neck-knife, those first two points are key and make the GSO-2.7 less suitable.
Of course, one can always strip the scales and wrap the handle. The scales are fixed with custom-length T25 torx fasteners, 416 stainless steel, these are black-oxide coated. A wrench helps, as they are installed TIGHT.
You can see the substantial skeletonnizing of the tang, and also the small hole denoting that this is a CPM-20CV model, and the shallow divot denoting "factory second":
A quick "strider" wrap with some cord, and the knife is slimmer, lighter, and actually better balanced.
Oddly enough, it still fits the sheath with reasonable retention:
I did some carving and also throwing of the knife like that and found that, while I prefered the lighter and slimmer carry of the cord-wrap, i prefered the scales for all manner of use that I put the knife to, pommel-flare and all.
Videos will be linked at the end of the review
Regarding the design, the GSO-2.7 is a beefy pocket-fixed-blade. From the stock thickness down to behind the edge, it is made to endure rough use and remain comfortable. Wihle I would recommend modifying the flare at the pommel for users with hands my size, the knife may be just right for someone with smaller hands, including children and women.
I would not call the 2.7 a "slicer" because it falls very short of my benchmark for such blades:
But the slicing performance is competitive with knives like the Izula which feature both a thick edge-geometry (>0.020") and also traction coating. The CPM-20CV is very corrosion-resistant and said to be very abrasion-resistant. I would be interested to see a performance comparison between this knife and a stainless Izula. I did compare it in performance to the 420HC Buck 140 Paklite and found it to be significantly more comfortable and also significantly more durable{/B]. Comfort was also higher than the Izula, durability seemed fairly close to equal.
The pommel features the same extended hidden lanyard hole found on nearly all S!K models, which can be fed a lanyard while the scales remain in place. On a knife this small, the lanyard may be decorative or to assist in locating the knife for drawing from a pocket-sheath. or to clip other tools to, etc.
Some more size comparisons:
GSO-10, GSO-5.1 (2016), GSO-4.7 (CruV), SK-4 (old 4.1 style), SRKW Rodent Solution (will be compared with the GSO-3.5 in a later review), GSO-2.7:
Personally, I prefer the uber handle-heavy Rodent Solution for comfort to the GSO-2.7. OH for a skeletonized RS!!
You can kindof see the similarity of the old handle-style feature in the 2.7 and the SK-4
Buck 110
Buck Vantage
SAK and Sodbuster Jr. (Bear & Sons) - much thinner, finer blades but very similar length
Benchmade 15030 Mini Bone Collector - I probably should have done a more thorough comparison of these two, as the Benchmade has a similarly stout blade of D2 steel and has a fairly robust handle which, aside from the excess of channels that grap your hand and the discomfot of a pocket-clip, is quite comparable to the GSO-2.7. In most circumstances, including outdoor use, I would prefer to carry the Benchmade folder to the fixed GSO-2.7, as it takes significantly less space but is more than enough knife for the same uses in my experience.
Specifications:
Blade Width: 1"
Buck 110
Buck Vantage
