chiral.grolim
Universal Kydex Sheath Extension
- Dec 2, 2008
Survive! Knives GSO-4.1
Guy Seiferd's 4" blade design has evolved into this:
Specs:
Length: 4.375" Blade (4.1" from tip to choil) + 4.625" Handle = 9.00" OAL
Blade Width: 0.43" saber-flat + 0.75" primary bevel + 0.06" edge bevel = 1.24" OAW
Thickness: 0.16" stock down to 0.03" edge bevel
Bevel Angle: 5-dps primary, 15-dps edge
Handle width/thickness: 0.78 x 1.12 Swell down to 0.65 x 0.94 index groove.
Steel: Bohler M390 hardened to 60 Rc; Skeletonized tang
Handles: rough canvas micarta
My first impression of this knife is that it is bulkier in width than I was expecting, but also lighter. The 4.1" blade (measured ahead of the choil) is ~1.24 inches wide - the flats of the saber grind are 0.43" while the primary bevel is 0.74" and the edge bevel is 0.06" wide while ~0.030" thick behind the edge sharpened to ~15 dps. Stock thickness is ~0.16", and the knife weighs in at a mere ~6.4 oz. Guy accomplishes this low weight on such a 'beefy' knife by skeletonizing the tang, removing extra material while retaining structural integrity and accomplishing perfect balance on the index finger immediately beneath the guard.
I will compare this knife to two others of similar dimensions, similar designs for a "hard use" outdoors knife: BRKT Bravo 1 and Swamp Rat HRLM.
The Swamp Rat has a longer handle (5.2") on its 4.1" blade, OAL 9.3". The blade is ~1.39" wide with 0.475" saber-flats and an edge identical to the GSO-4.1 (0.06" wide x 0.03" thick, 15-dps). Stock thickness is ~0.187" but the coating brings it to 0.19". The knife weighs ~9oz with its wider profile and un-skeletonized tang, balancing ~0.75" behind the index groove.
A skeletonized tang for good balance is a promoted feature of the BRKT Bravo 1. This is an original A-2 version - a better comparison would be the rampless spear-point 3V version of nearly identical profile to the GSO-4.1. The A-2 Bravo 1 weighs ~7.5 oz, convex-ground from ~0.22" stock down to a "zero edge" (no secondary bevel) 0.015" back 0.06" from the apex. The edge approximates 8-dps, hardened to 59 Rc. I have read that the CPM-3V versions are thicker behind the edge and heavier, but I do not have the measurements. The BRKT's handle is slightly longer and thicker than the GSO.
Specs:
