- Apr 14, 2008
I was bored so I thought I would try out my swedish mess kit with trangia cooker. I lit it up in the kitched and noticed a few things. I looked it up on U tube but didn't learn much. No instructions with the stove. If you place the pot square on the base, pot matches base, mine won't come to a rolling boil. It would be good for a simmer but wastes the same amout of fuel. If you turn it sideways on the base, the flame will leap to the lip of the pot along the sides and begin to boil the water, much hotter. If you play a stringed instrument, a wrapped string will clean the holes well. Just put a pigtail loop on end and nip it about 1/2 inch. Easier to grab and use. I just leave it in the bottom of the stove all the time so I know where it is if I need it.
I received a Svea 123 stove with Optimus windscreen and pots for Christmas. The Svea is packed in the kit without a windscreen and you are to use the larger cook kit one. The Svea 123 without windscreen will fit in the Swedish cooker base. I have used it without a problem but have been advised not to do it on this forum. It would seem that the optimus cook kit would have the same problem. Just thought I would pass this on. Has anyone else noticed the same on the Swedish military cook kit? Made a mistake. Had the cooker base upside down and the stove resting on the wire arms. So, learn from this. Don't do that. Regards.
