In what was either a stroke of pure genius or a moment of total stupidity, I figured out how a Compact or Climber model swiss army knife can be used as a handle for a t-shank saw blade.
The t-shank is trapped under the parcel hook. It's not exactly rock solid, but it seems to work well enough to easily saw through a pencil.
If anyone would care to try this out in the wild, then I would be interested in hearing about the results. If you do try this, BE CAREFUL!
This is obviously not the way these tools are intended to be used.
I think this is a pretty cool discovery. It means you can add some limited wood and metal sawing capability to a thinner SAK without increasing its weight or thickness. Obviously you wouldn't want to depend on this trick for regular use, but it could work in a pinch and it allows you to increase the overall capability of your swiss army knife for only a small weight penalty.
