I did a little test between the Leatherman Micra, standard 91 mm SAK scissors in a Climber, and the serrated Wenger scissors in the Vic Evolution 14.
First, I did a couple of cuts on thin cardboard, i.e., not as thin as paper, but not very thick either. All three did fine cutting paper/thin cardboard. Then I did some cuts on a zip tie. I've used the Micra extensively to cut zip ties and its a zip tie cutting machine. The standard SAK scissors cut it, but not easily or well. The SAK scissors wanted to squirt the slick plastic out. They took a lot of pressure and then the cut piece rocketed across the room. The serrated scissors, otoh, gripped the zip tie and snicked right through it. Took less pressure and had way more control.
I was ready to proclaim the serrated scissors vastly superior, and was going to start a new thread, then I thought, "use the search function"
and found this thread. After reading the comments about paracord, I went and got an old boot lace that I've used to make a couple of lanyards. Interestingly the standard SAK scissors cut it without drama or effort. The Micra and Evo scissors, otoh, mushed it around and took more effort to make a less clean cut.
I also saw comments about denim
I didn't have any denim I wanted to cut, so an old sock had to stand in. The Micra had a hard time cutting the sock. Really didn't work very good at all, The Evo did a better job, but the cut was ragged. The standard SAK scissors just snicked right through without problem, making a clean cut.
My conclusion is none are clearly better than the others. If you're going to be cutting a lot of zip ties, get a Micra. Cloth or paracord, then the standard SAK scissors seem to work the best. I like the feel of the Evolution scissors better, and they certainly work better on hard, slick stuff like zip ties than the standard SAK's, and work better on cloth than the Micra, so not a bad compromise.
