Swiss Army Knives with pocket clips! Also a Gerber MP600 and Buck Vantages
chiral.grolim
Universal Kydex Sheath Extension
Feedback: +79 / =0 / -0
Prices are USD and include shipping via USPS with tracking, international buyers must help defray extra. Buyer must conform to all national/state/local laws and assumes legal responsibilities.
Post "I'll take the ***** " indicating which knife and send me a PM or e-mail to follow up for payment information. Thanks for looking!
First are production Victorinox Swiss Army Kknives, all purchased new-in-box, then modified by addition of a pocket-clip directly to the non-presentation alox scale (orients the knife for right-front-pocket tip-up carry of main blade).
These make great gifts and are very office-friendly. Adding the pocket-clip increases the likelihood that the owner will carry and thereafter enjoy using the knife. Don't miss out!
This is my current list of models on-hand and ready to ship. The clip I had been using was evidently discontinued, so I am trying out some new options, both deep-carry - the new Leatherman 'FREE' pocket clip (only available in polished version) as well as a Lynch-style clip. These are bit more expensive but they do the job well. You can demonstrate your preference by ordering one here or emailing me with a request! I do have a couple of 2016 Orchid Pioneers and 2018 Berry Red Pioneers on-hand just waiting to be clipped. If you don't see a model you'd like clipped, just let me know and I can order and clip one for you. Here is a link to more photos: https://imgur.com/a/gzGsrYt
Limited Edition 2018 Berry-red Pioneer (currently clip-less)
Limited Edition 2016 Orchid Pioneer (currently clip-less)
RED Pioneer X with leatherman clip $65 - comes with leatherman lanyard-attachment and torx driver
Blue Farmer (black clip) $60
Green Farmer
with lynch-style clip $62
Rancher / Swiss Army 6 (gray clip) $55
Silver Electrician (gray clip) $50
Black Pioneer (black clip) $50
Buck Vantage Avid 13C26 steel with Diamondwood Scales - barely used, razor sharp, flips perfectly, excellent lock-up (I can make a quick video if desired), perfect centering, includes original box, hard to find disco'd model (AEB-l steel). Has some wear on the scale-finish, and there seems to be a wierd discoloration on the blade (not sure from what, hard to capture in photos) but otherwise is perhaps the best example of a Vantage you could come across. I also added a back-spacer from a Vantage force but can switch it back to the original set-up if desired. $65 to your door.
Buck Vantage Force Select
but I have swapped the regular scales for a set of G10 scales from a Vantage Pro. The knife is otherwise brand new, never carried or used, includes box. It flips OK (not as well as the Avid above), has a strong/stiff liner. $47.
Gerber MP600 Pro Scout # 47563
Here is the link to Gerber's site: https://www.gerbergear.com/Multi-Tools/One-Hand-Opening/MP600_47563
The multitool is new-without-box but includes paperwork and sheath. This version has integral wire cutters (actually stronger than the replaceable ones), scissors, and the replaceable saw-blade (you can blades for cutting wood and metal from your local hardware store that fit the adapter). $40
I can offer a MOD on this tool (for a little more $$), modifying the handles to allow the needle-nose to retract further in and lock in place if desired. I can also modify the tiny flat-head into an awl if desired. Let me know if you want pics of examples.
This is a great, sturdy pliers-based multitool at low cost, made in USA.
So you can get any SA set up to be used with a Lynch?
Any of those neon green available for that?
Thanks!!
email me thepritz at gmail. I gotta renew my gold so I can PM but email is good for now. Thanks!!
The pocket-clip mod is for Alox-scaled SAK's, and I can add inserts and screw to G10/wood customized models, but I can't do the hollow plastic/cellidor. Alox is easiest to come-by, hence what you see here.
The raised pivot-pins on the Alox require a clip that avoids the pin-head, but I can accomplish that with the lynch-style clip by slightly countersinking the back of the 3rd hole. The leatherman clip is nicer in that it was designed to avoid a pivot, no modifying required. Also, hole-placement for the leatherman is easier to drill. *shrug*
Just FYI your test for the first vantage says AEB-L.
Yup, Sandvik 13C26 steel is the same composition as AEB-l, is the same steel and not often encountered in production knives, esp. USA- made knives. Awesome stuff, takes a very keen edge, very easy to restore, corrosion resistant and tough.
