Hello, as the title has stated, I'm interested in designing a sword stick, but I've only done online research and would love to hear from more experienced individuals who may be able to provide insightful information regarding its practicality, price, etc.
I've done some measurements and found that the height between my arm and the ground when the former is bent at 90 degrees, is approximately 47 inches/119.38 centimeters, but the total length of the stick will likely be 50 inches/127 centimeters. The handle will probably be 10 inches/25.4 centimeters long while the blade occupies the remaining 39.5 inches/100.33 centimeters while being 1 inch/2.54 centimeters wide. Though the sword should be rapier-ish in style with its primary function being stabbing and thrusting, I also would like it to be able to cut decently, if not well. which is why I'm not entirely sure what the blade shape or fuller will be quite yet.
I'm hoping the sword itself will be something similar to this: http://bladegathering.com/wp-content/uploads/2014/10/DSCN3956.jpg
But with a much longer blade and handle, and without the engravings or externally visible metal pieces.
Something much closer in appearance when sheathed would be: http://new.uniquejapan.com/wp-content/uploads/2011/11/shikomitsue-33-Edit.jpg
Of course, with the aforementioned differences and a matte black lacquer instead of a glossy one, as well as a oblong shape to help with edge alignment.
Another detail I hope to include is a counterweight within the flared end of the stick, as in the place where you would rest your hand when using it as a walking stick, to make the sword easier to wield, unless its not needed for this type of sword.
I'm not sure how the sword would be kept in its sheath besides the button release/lock mechanism that most cane swords use, but I'm not overly fond of that design as the button is usually noticeably visible to anyone that bothers to take a second look. If there are any other, more discrete, and preferably internal mechanisms that can be used to the same degree of effectiveness, please don't hesitate to mention it.
Now, onto the materials.
I've looked through common sword steels like 1045/60/95 Carbon Steel, Spring Steel and Tool Steel, with three steels that immediately stand out to me: 9260 Spring Steel, L6 Bainite and S7 Shock Steel. 9260 for its reputable durability, Bainite for its apparent reputation of being the toughest sword steel on the market, and Shock Steel which is described as sharing many similarities with Bainite, but I could find little further beyond that. If you guys have any better recommendations or recognize any of these steels as being the 'best' (when properly heat treated of course) do tell.
If the counterweight is possible, what material should be used for it?
For the stick itself, what material should it be constructed out of? I'd like it to be quite durable as well since a situation could arise where it might be used as a bludgeon without drawing the blade or as a back-up weapon.
And once everything has been decided, if there are any custom swordsmiths that excel in creating these types of weapons (in any country), don't be shy about recommending them.
Finally, my price range is $1000+ US, though I would like to keep it below $2000 US.
If I have missed any details or if you have any questions and/or comments about the sword stick, don't hesitate to post them. I'll try to answer them to the best of my ability.
Any help on this would be greatly appreciated.
Thank you!
Thank you!
