I spoke with Brian Morgan from System Three on the phone today.
He says not to assume the viscosity is too low based on the numbers on paper. He is a knifemaker himself. He and a number of other knifemakers have been using the Blade Pro formula for a while with excellent results. He says it is still thick enough to stick to parts and not drip all over the place as you're trying to assemble the knife. The lower viscosity was definitely to aid in pouring into handles etc.
I asked him if he tested his formula against G-flex and others. He said they did and the Blade Pro epoxy either slightly exceeded or way exceeded G-flex in all their tests. He claims the Blade Pro formula is much better than the T88. There was some other information that he shared with me but that information is not ready for broadcast yet.
I asked him about a lot of things. These are some things I learned. I'm not a technical guy so forgive me if some technical terminology is not precise. The Blade Pro formula was formulated with a rubber component that gives the epoxy a lot of toughness and the tenacious grip it has on disparate materials. It excels at bonding to a variety of metals, oily woods, natural and man-made materials. It is stable and unaffected by wide temperature ranges. For example, a full tang chopper used in sub-zero temperatures or a kitchen knife (with waterproof synthetic material handles) in the dishwasher, all good. He says rather than using dyes mixed in with the epoxy they offer colorants for their epoxy which is actually colored "part A". So it is the same component that the epoxy is made of. He did mention that like all epoxies, it will start to soften at around 120˚f. I asked him about larger sized bottles. He said they may take a look at that in the future depending upon demand. Shelf life is indefinite as long as it is stored well, but at least three years.
I probably forgot some other things but those are the basics of the conversation.
