Modernflame
- Jun 12, 2021
I don't like the factory edge on this tanto Sebenza. I want to sharpen it, but I'm struggling with the approach and I'd like to solicit opinions. If the main edge is 20 dps, then it seems that the tanto grind must be fairly similar, as the bevel width is the same near the corner. The tanto edge gets wider with the increasing thickness of the steel.
The factory has applied a lovely belt satin finish to the tanto grind with a very obtuse micro bevel. The appearance is magnificent, but the micro bevel is so obtuse I struggle to measure it. It cuts like a splitting maul. To be clear, when I speak of cutting performance, I'm talking about the part of the blade circled in red. I know the main tip is not designed for fine cutting.
It seems to me the options are:
1) Flat grind the tanto edge at 20 degrees per side to match the straight edge. The result will be better cutting geometry, a coarse diamond finish, and a crisp tanto corner. However, I will loose the belt satin finish.
2) Get over it and follow the factory micro bevel.
How do you guys approach this?
Edited to reduce the wall of text.
