Stromberg Knives
strombergknives.com
- Jan 3, 2015
Hey guys!
I'm using my surface grinder attachment for tapering tangs and spines. I like this process a lot, works great. But I've found that I'm having trouble finding the correct angle of the attachment depending on the thickness at the end and the length of the portion I want tapered.
I would like to be able to calculate the distance between the "tapering bolt head" and the magchuck, and put a correct size shim there. I thought I'd make some sort of excel matrix with the stock thickness, taper length and target thickness.
Unfortunately, my math keeps failing me. I have such a matrix for bevel grinding, but it returns the answer in degrees. And I can't seem to figure out how to convert those degrees to the distance between the bolt head and the magchuck.
Any mathematicians on duty today?
It would be greatly appreciated, thanks in advance.
