- Jan 18, 2017
It seems like it was designed for combat not utility. E.g. stabbing, not chopping. It's obviously not designed specifically for wood work, so any criticisms of it based on it's lack of ability in those areas are probably missing the mark.
Having stabbed a few pigs with my TGLB, I can say the double guard helps to stop your hand sliding forward; you have to push hard with a blade that thick, and the pig is wriggling and you're moving around a bit, and there's a chance of your hand slipping onto the blade.
The fuller also helps with a quick kill or so I've been told (I haven't done this enough to know myself). The heart is inside a lot of liquid and pressure from other organs and when you puncture it, it 'self-seals' and slows the process of bleeding out. The fuller introduces a pocket of air into the heart and kills it instantly. This is good for the pig, and good for you and the dogs.
If you are buying a knife for other uses of course you would buy a model designed specifically for those uses, you wouldn't buy a TG and then complain it doesn't do what you wanted.
But a TGLB is a beautiful knife, feels amazing in hand, and is great at what it actually does! Also, it can do the other things at a pinch which is handy when you don't want to carry two knives.
I should have read the whole thread before posting, because I basically repeated most of your points. Anyway, right on!
