I`ve been playing with bench grinding techniques with some success. I made up some adjustable guides that allow me to grind the blade stock evenly. I set it to grind at 3 different distances from the edge so that the hollow grinds overlap. This leaves 2 slight ridges along the length of the stock. I use a 4 1/2"angle head grinder to remove most of these. Final shaping is done with a sharp mill file,using a straight edge to check my progress. This technique allows me to achieve a pretty nice flat grind up to 1 1/2" from the edge. Some mods on the guides will allow 2" from the edge. The only problems so far are that it`s time consuming and to get the grind right from plunge cut to tip the spine must be parallel to the edge all the way to the tip. I`ve been cutting the blanks out like this,doing my bench grinding with the guide,then cutting the spine to the profile I want and finishing the edge grind with the hand grinder and file. Final finishing will be done with a variety of air sanders. Seems to be working out okay,the test pieces I`ve made so far look pretty good (for a beginer) it`s just very slow. I`m having lot of fun though so I may have to invest in a belt grinder at some point to make the job easier. Marcus
