Yeah, it'd be compatible. Also, while "self lubricated" Teflon/PTFE works best with oil, the PTFE particles shouldn't harm anything.
Op how was your outcome after adding ptfe to your Teflon washers?
I have tried teflon dry spray on xm18s
Spray it on both sides (washers only)
Then just lightly wipe it dry
Works very well and you don't have to worry about getting oil on blade or lock bar
Lot of people even run them dry without anything
Superlube does work very well. It's a PAO oil with PTFE I'm it, and their grease is essentially that with a thickener. In a rolling application the coefficient of friction may very well be reduced to such low levels that the PTFE would slide rather than roll and cause flat spots such as in those rollers. But this is a sliding/rotating application and that reduction in friction will be beneficial.
Example: Those door hinge rollers on older (70-80's) GM cars used Teflon bushings so those heavy doors would "feel" lighter opening, and closing.
Remember that "Creeeek" and the stiff spots that would occur. That sound, and stiffness were caused by mechanics at dealerships (or well meaning shade tree guys) applying everything except PTFE based lubricants.
If an item uses teflon as a washer/bushing then ONLY PTFE based lubricants should be used.
Teflon and hydrocarbon based lubricants are much like oil, and water. They just don't mix well.
i dont understand. ptfe = teflonMy primary concern was that the PTFE lube would break down the Teflon washers.
My primary concern was that the PTFE lube would break down the Teflon washers. Kind of like the way silicone can absorb silicone-based lubes, swell, soften and eventually fall apart. Glad to hear that this isn't the case here.
Or perhaps the concern was that the carrier solvent(s) keeping the PTFE in solution would attack the washers.
This one is a site that lists the MOST common chemicals, and plastics...
http://www.plasticsintl.com/plastics_chemical_resistence_chart.html
I've always considered wd40 "aerosol kerosene".WD-40 MSDS...
"64742-47-8 45-50" is the CAS#
"Kerosene" Cut an apple for your kid now!
