Tenacious washer sizes?
I've searched but can't find the sizes of the washers for the Tenacious.
There are 2 different size washers. I'd like to get ID and OD for both sizes. And thickness too.
All I really need is the ID size for the pivot at a minimum.
In my research I found that Spyderco won't send washers for the Tenacious because it's not made in Golden, CO. If that's not correct let me know.
Well, if you want something done...
It appears the ID for both is ~3/16"
The lock bar side has an OD OF ~3/8"
The non lock bar side had an OD of ~ 1/2"
All very unscientific measurements.
Now if anyone could help with the thickness, that'd be great.
I am killing myself trying not to send the knife in for half of what it cost to buy(bought it for a friend who messed his up) trying to find this information. If you can help out so long after your issue, that would be awesome!
Hello,
Sorry it took so long for a reply.
What exactly are you wanting help with?
Here’s another thread I did and someone gave me the exact measurements.
[URL]https://www.bladeforums.com/threads/spyderco-tenacious-washer-dimentions.1052616/#post12017283[/url]
And another thread on the topic.
[URL]https://www.bladeforums.com/threads/how-would-one-go-about-replacing-washers.1307298/[/url]
What I ended up doing was - I lucked out and found someone selling a set of Paramilitary 2 washers on eBay.
I used those. They work fine.
There are only 2 washers, one per side, not 4 washers, two per side.
Like I said it works just fine.
If you can get Spyderco to send you some PM2 washers they will work.
I don’t know if they do that or not.
You can’t see the washers through the clip screw holes which I like.
Here’s a third thread on the subject with pics of my knife.
[URL]https://www.bladeforums.com/threads/spyderco-tenacious-help.1239946/[/url]
I hope something here helps you.
If not, let me know why you’re looking for and I’ll try to help.
