I bought a RADA Cutlery Santoku a few weeks ago and have been using it for cutting vegies and such on a plastic cutting board. It would occasionally stick on the board on cutting, but only with tough cuts that required a bit of pressure, and even then, just enough to notice. For anyone not familiar w/ RADA, the knives are some form of stainless, mirror polished and about 1/32" at the spine, with a very thin edge. A 6" knife cost me $7 a the local flea market.
So, I decide to see how much of an edge it will hold on cardboard. I resharpened the knife with an 800 grit waterstone at 12 degrees to form a burr, and then used the 15 degree slots on the Sharpmaker with Medium flats of the rods. This produced a very sharp edge, capable of making strips of a plasting grocery bag. Much to my surprise, after only 10 cuts, the blade would not cut the bag.
As a check, I resharpened a Kroger house brand steak knife to the same profile using the same stones. This knife also came out very sharp, easily cutting the bag, but not as cleanly as the RADA. It took nearly 30 cuts to dull it to the point that it would not cut the bag any more.
I have compared the Kroger to my 805 TSEK in 440C from Benchmade, when both were finished fresh off the leather belt of the Harbor Freight belt sander. It came in at about 60% of the 440C, but I dont know for sure how close the blade angles were, as I just use the flat of the blade as a guide when using the sander, meaning I tilt the blade back (increase the angle) until I can barely see the flat of the blade, and then use this as the sharpening angle. It falls between 15 and 20 degrees, as edges off the sander can be touched up on the 20 degree sharpmaker slots, but not so much on the 15 degree ones, unless I take great care to use a very shallow angle.
Just to be clear, both blades were still quite sharp and easily usable in the kitchen. Both would still shave hair, even when the plastic bag could not be cut. There was a noticable roll on the RADA blade, and the Kroger blade as well. There may have been a slight burr left, but I used Jeff Clarks method of deburring with the Sharpmaker, which involves taking 30 degree per side strokes into the stone to remove any burr, then taking a few more to freshen up the edge.
Since I didnt use hardly any cardboard, I plan to repeat the tests tomorrow night using the Sharpmaker White stone fine finish, and then again at a 17/20 degree per side profile.
Every kitchen I've been in around where I grew up had several of this brand of knife. I'm quite surprised at the results, and suspect I need to repeat the test at the current angle/grit, but use a more extensive deburring step, to eliminate that possibility.
I would hazzard a guess at the hardness of the RADA blade at about 50-53 HRc. I just finished a 1095 Kiridashi that outlasted both knives by a factor of 10 and 5 for the RADA and Kroger respectively. The sharpening angels for the kiridashi are probably vastly different, as all the grinding and sharpening on it has been done free hand, including the finish sharpening using the Sharpmaker white stones.
For future reference in this thread, I rarely use the corners of the Sharpmaker rods anymore. They tend to cause more burrs than I've used them to remove, just due to the small contact area pushing the edge around a little. I say that just so from this point on, in this test, only the flats will be used for sharpening when putting on the final 15 or 20 degree bevel from the Sharpmaker.
Any more detailed info on either of these knives, and the RADA brand in general would be appreciated.
