TESTING Spyderco S30V vs. VG10
I'd promised to post this as soon as I'd finished. Here it is...
I recently went on a week long holiday to Cairns in tropical North Queensland in Australia where the days are warm and the nights are balmy. It was the wet season, with torrential rain everyday. I used this trip as an opportunity to test my 2 new-ish Spyderco folders. The Spyderco Goddard is a large folder in VG10 steel and grey FRN handle. The almost 4inch blade is deeply hollowground. The Spyderco Native is one of the new ones in S30V steel, and was my first knife with S30V. The Native was brand new straight out of the box. The Goddard had been used a fair bit and prior to testing I cleaned it and resharpened it back to factory specs.
Spyderco Goddard
Spyderco Native
I used both knives (not abused) during the stay for everything that required a knife. There were a LOT of fruits that demanded to be eaten and all the kitchen cutting was done using these 2 knives. I also carried the 2 clipped side-by-side on my pants everywhere I went. I also wore them on my BOARDSHORTS, taking them swimming - in the pool and also on a trip to the Great Barrier Reef. I did a fair bit of cutting, whittling and slicing of various items to keep checking the edge quality all the way along.
The tests I did were "miscellaneous" subjective tests in basic day to day use, not specific, controlled tests or any sort of abusive / breakage tests. I felt that 2 Spyderco knives with high-quality heat treatment and very similar grind shape and thickness, would help control for extreme differences between knife models. I am aware of the disparity of blade length.
The areas I wanted to mainly look at were edge holding, quality of the edge, stain resistance and ease of sharpening.
EDGE HOLDING & EDGE QUALITY
Interesting Results...
I push cut hemp rope, cloth, whittled twigs for no good reason, sliced mangoes and fruits, to test the initial sharpness of both and then again after the trip to see how it would go.
Both blades shaved hair readily. The Goddard VG10 as it came to me, would cleanly knock individual hairs off. It had a fine, almost polished edge that just grabbed anything aggressively. Twisted double 1/4inch hemp rope offered little resistance - lovely crunch, crunch through the rope. I only did 4 cuts. Whittled some dried wood, which gave beautiful clean shaved slivers. Cut down easily into ripe mangoes without denting the skin.
The Native S30V blade had a rather rough looking edge that had clearly been ?? polished at the factory. The very edge was nice and even but the edge cannel itself looked like it had been cut with an 80grit belt. The edge angle was also a little steeper and narrower than on the VG10 blade. It would shave hairs but required greater pressure, and I noted that it tended to not push cut through hemp rope as well. However, it excelled when a slight sawing motion was added. It ripped through the hemp ropes and stuck itself into the plastic chopping board when I applied more pressure. Again, with whittling, I had to apply a little sawing action to cut slivers, which tended to split and peel off.
By halfway through the trip, both blades were showing some change in edge attitude. Neither blade would shave any more, but the VG10 blade still coudl slice very thin slivers of wood from dried hardwood twigs. The S30V edge could not do this at all, and required a sawing motion to get through most things at this point. Cutting tomatoes and soft vegies became more of a chore. The VG10 blade would still slice more easily, but there was no advantage if a sawing motion was used. The S30V blade really benefitted from using a sawing motion.
However, the S30V blade suddenly would not push cut AT ALL. I had just been cutting carrots on a wooden chopping board, when I had to use inordinate pressure to get it through the carrot. Instead of cutting in, it crunched its way through the carrot. A quick check revealed a massive flat spot 1inch long along the middle 1/3 of the blade. A closer check then revealed that at many areas along the edge, there were quite large (visible) areas of microchipping which gave the edge a saw-tooth profile.
Its hard to see, but you might be able to make out the ragged edge and the very coarse grind for the edge bevel.
The VG10 blade was going strong, with no evidence of flat spots.
At this point in time, I had to terminate tests of edge holding, as the VG10 blade was clearly the only blade that could be used for effective cutting. I continued using the Goddard VG10 for utility purposes, but no further comparisons could be made. I'd forgotten to pack my EZELAP Diamond hone...
PLease see the bottom of this post for the epilogue.
STAIN RESISTANCE
The results were not a surprise to me.
Both steels are 18% chromium steels. However, the VG10 blade had a very fine ?? almost 1200grit surface finish and along the grinds as well. The S30V blade had a very coarse grind. The flats were ?? probably 400grit appearance, while the edge bevels were no greater than 80grit from what I could see. (See the pictures above for the S30V blade / edge coarseness.)
I was careful to ensure both knives were used equally. I washed and dried both knives simultaneously and did not lubricate or clean away any corrosion that occured.
The VG10 blade definitely started to subtly stain with areas of use coming up a subtle blue-ish tinge. One rust spot appeared in the plunge cut but nowhere else. The edge itself actually went a bit darker, quite obviously, but there was no spotting or pitting anywhere to be seen, including on the lockbar.
The S30V blade was showing signs of stress !! Areas of frank rusty deposits and pitting were showing up in the pivot area, and all along the edge and grind. The blade opening started to get a bit gritty, which required a little work later on after the trip to free up.
Here are some shots. See also the pictures above.
RESHARPENING
I had to defer any resharpening until after the trip was over. Back in Melbourne, I used the (Red) Fine EZELAP diamond hone to re-do the edges. I used the free hanging paper slice test as the standard to say when the blades were equally sharp.
The VG10 blade was returned to the desired sharpness with just 8-10 light strokes (back and forth) on each side along the edge. This took only about 90 seconds. This was despite having been used twice as long as the S30V blade during the trip.
The S30V blade was stubborn. It didn't help that there was a massive flat spot along the blade. I was faced with either sharpening at a blunter angle to remove the flat spot, or to cut the entire edge higher. To "save time" decided to sharpen at a more obtuse angle to get rid of the flat spot. This took me about 8minutes to achieve. This sharpening procedure also demonstrated how deep and coarse the grinding grits were when shaping this knife.
Both blades also then got a finishing with a medium (grey) ceramic stick which got both to a hair-popping sharpness. The VG10 blade took 4 strokes per side to do it. The S30V blade took 9 strokes per side to do it.
I then also used s leather strop loaded with compound to polish the very edge to shave hair off my leg. The VG10 blade got straight razor sharp within 2 strokes per side. The S30V blade required 6-7strokes per side to do the job.
There is a TWIST - see my conclusion.
CONCLUSION
Its clear from my account that I became very biased towards the VG10 blade from early on. The S30V blade didn't help by suddenly developing a flat spot right in the middle of the cutting belly that made me abandon side-by-side testing. From what I could see, the VG10 held the finer, stronger, edge for longer. It was also easier to sharpen and overall seems to give the better performance.
The finish of the blade definitely made a difference. The coarse grit surface of the S30V blade clearly placed it in an awful spot for corrosion and it meant that the edge was always going to be prone to corrosion-induced dulling. Its not a simple matter of saying that all will be better if the blades were both finished to the same degree. I feel that manufacturers are unlikely to be willing to invest in the increased tooling and work costs of more finishing on S30V. Therefore, I feel that coarse grit finished S30V blades will be the norm.
The TWIST
However, an area of focus that could seriously improve performance on these blades appears to be the edge bevel grind. After the resharpening process, I have continued to use both these knives side-by-side in informal utility chores. So the "testing" continues. It is clear now that the S30V blade is holding its edge (which now shaves) better than the VG10 blade.
Therefore, I can happily say that there will be more observations to come.
As mentioned these were fairly amateur-ish mundane tests that I thought represented basic knife use in day to day life. I hope this is useful to some... and not too boring to all. Cheers. Jason.
I think it would have been better if you sharpened both knives to the same edge angle and same finish before starting your test. I don't know how you could come to any sort of conclusion, even a rough one, when starting with whatever edge the factory put on it. The Native may have even had damage to the edge if it got to hot being sharpened on a belt sander. You may have to remove some of the metal at the edge to get back to properly heat treated steel. This could explain the chipping as the factory edge may have been to hard.
Excellent review. VG-10 cuts very aggressively, judging from my F1, better than any other stainless steels IMHO (ATS-34, SAK, 420HC, 12C27). Haven't tried S30V yet tho'.
Thanks for the good read and pics.
I am a big fan of VG10, I reckon its the perfect steal for a small to medium sized EDC folder. The grey FRN Calypso Jr is a good example of this, takes an amazingly sharp fine edge that lasts, yet easy to touch up when required.
S30V might be tougher and hold an edge longer, but often gives me grief trying to produce the edge that I am after.
Jerry Hossom has a lot to say about how sensitive S30V edgeholding is to how fine of a grit is used for the edge. It works much better with a finer grit finish. In my use, comparing a VG-10 Calypso Jr and S30V Native, I find the Native to hold its edge noticeably longer.
Yeah, I think the results you see after sharpening both edges to the same grit will be more meaningful. My Paramilitary came with a coarse edge like your Native, and did not perform well at all. Being familiar with the steel, particularly in a couple of customs, I was disappointed. After reprofiling, a finer grit edge, and mirror polished back bevel, its performance took a huge step up from its out-of-the-box condition in both cutting ability, and durability.
Nice knives and pics. I look forward to hearing how they compare after more use. I love both steels but have done no side by side testing, just have impressions from general use to go on (which are that S30V is tougher, and holds an edge longer, while VG-10 is more stain resistant, and easier to sharpen).
I tend to agree..especially with the last part of what you said. I don't claim to use my knives so much that the extra last bit of edgeholding matters that much. If it's a quality steel in a quality knife with a quality grind...that's what counts.
Nitin
Hi Jason,
Could u please tell me how did u take those macro pics on the knives' edges? Which lens did u use? Informative aside, they look cool too. :cool:
My own tests involved a Endura VG10 and Paramilitary S30V. The VG10 Endura blade held an edge longer than the S30V. It would sharpen up easier and faster as compared to the Paramilitary. My paramilitary lost its slicing and shaving edge after just cutting through a couple of (Teva-like) sandal straps (made of nylon and pleather). It took me a good 10 minutes on the sharpmaker before it would shave again. It doesn't take to stropping as well as VG10.
For spydies, I'd have to say that VG10 is my preferred steel. The finish is so much nicer as well.
Glad I'm not the only one to notice that VG10 spydies out-rock the S30V ones. Perhaps it's really the finish-grit, like what Jason observed.
Great post mate! (good shots too.)
Hopefully you didn't pay retail for those Sypdies! :)
Thanks for the great review and pics. It confirms my observations too. Both are great steels, maybe the S30V is a wee bit tougher. Looking forward to read your "phase no 2" testing(s). :cool:
I've been looking out for a VG10 S30V steel comparison for a while. Thanks for doing it.
I noticed that my calypso jr had a very course grind whenit came. It also had a fair sized burr so needed a bit of work. It is rather good now. I am now happy even though I can't afford the uk penknife.
I look forward to seeing a comparison after both blades have ben sharpened in the same way
Thank you for that excellent review. I have been interested in this for quite awhile, and that was very professionally done. And I, for one, am glad that the review was done "out of the box".
Jason,
Excellent report even with the (slightly) flawed experiment. What that showed was the difference between the adequate factory edge and the way the edge should be. As you say
The only VG-10 knife I own is a fully serrated Spyderco Delica which I keep in my truck console and hope I never need to use. Maybe I should have bought the rescue, but the Delica seemed a better GP blade.
Regardless, it's an experiment I couldn't run. I could do a Benchmade 940 154CM vs 940 S30V test, but I already know the outcome. 154CM would dull a bit sooner but would be easier to sharpen. 154CM would stain sooner and in a prying role, 154CM would break before the S30V was stressed.
??? Would someone like to run this test with S30V vs D-2? ???
It would be quite a mistake to take your experience with a single blade from a single manufacturer and extrapolate to all manufacturers. I can assure you that this isn't the case, as a review of various S30V blades from any number of manufacturers will show. With regards my own RSK Mk1, for example, the finish is quite fine to begin with and it is then "stonewashed" (tumbled) to further enhance the finish quality and resistance to corrosion.
Doug Ritter
www.dougritter.com
