Testing...testing...Behemoth Chopper
Lorien
Nose to the Grindstone
Moderator
I'll add content as I run this knife through its paces, and once its sheath is finished.
For now, a little black willow devastation;
Nice pics :thumbsup::D
I really like the color of the blade. The stonewash looks dark in color.
you can speed it up 2x. You'll find it's actually 1158 chops:D
Does autosol help with corrosion resistance like mineral oil or is it purely for cleaning/polishing?
That first video sure puts into perspective how damn big that things is! Photos do not do it justice
The fir I was chopping was flat on the ground, and my back appreciated the extra 2" of reach the BC has over the other CPK choppers I use.
It's highly likely that the chopping you saw there may not have impressed you very much. Part of the reason why I was so sloppy was because of the thick, winter gloves I was wearing, which have a Goretex layer sandwiched between insulating layers. There is a lot of slip within the glove due to the ptfe membrane. I found the knife quite difficult to aim, and my hands and forearms worked twice as hard as usual in keeping the edge from deflecting as it stuck the frozen timber. I usually handle this kind of work bare handed or with thin gloves, but I wanted to test both the lanyard placement's mechanical and retention characteristics, in addition to the handle shaping and took the opportunity to due so when I had my worst case scenario gloves on hand, (sorry for the pun).
The main aspects I wanted to observe yesterday, in this uncharacteristically cold weather, (-2 +/-)were the steel's various attributes. That fir was still green, and a lot older than its diameter would suggest. From time to time, I come across trees which have worked very hard to get up to the sun, for quite a long time. They are spindly, but very, very dense. This one had also been frozen for days.
To this point, I have neither sharpened nor honed the knife. I've cleaned it with Autosol, (which in my experience will very, very slightly blunt the edge, as part of what it does is remove material) and that's it. I will restore the edge before my next use of this knife, as its efficiency for some things is degrading slightly, but it's still quite sharp. Maybe I'll check it on paper to see what's up...
