Forrest Taylor
- May 13, 2021
So I just got a knife I sent in for heat treat to texas knife makers supply. The blade was CPM 3V.
Someone had written D2 on the tang. Now prior to sending it I had engraved CPM3V so WTH.
I called them and they said they heat treat all blades the same, 1880 degrees for 15 minutes and then temper for 500 degrees twice for 2 hours.
Now that's not what CPM website states for 3V. I told him what the manufacturer calls for is 1950 degrees 30-45 minutes and 1000 degree temper three times two hour minimum.
The guy I spoke too said that's what management dictates because they don't want to do different temps for each type of steel.
So now I'm wondering what kind of blade I ended up with. The whole idea of going with 3V was to get better toughness and wear resistance that D2.
Boneheads should have just sent it back and told me to find someone else.
If you are wanting D2 done I guess they are fine.
Boneheads
Looking at Crucibles website it may be that it is slightly higher HRC but less toughness.
Boneheads
