- Dec 5, 2005
I damaged my Mad Science Forge titanium bush sword while working on a trail last week. It was a four hour cutting session, and I got most of the nasty bits at least travelable, but I was getting tired and sloppy near the end. It's a testament to this tool that I was able to thwart damage for so long, mostly due to the light weight of this cutter, but also to the design which enables wicked accuracy.
Cutting ferns is a little scary, because you'll often find rocks hidden beneath the leaves, and found a rock I did. Now, I've damaged a good number of very high end knives, all of which are steel. I guarantee you that if this happened to a steel knife, there'd be chunks missing. This ductile titanium not only work hardens, enabling a long living working edge, it is maleable enough to give way under heavy load without chipping out.
Sandwiched between some soft aluminum and squished flat in the vice;
The ripple flattened enough for hammer time;
Hit er up on the grinder, and we're back in business!
I'm in love with this, my most useful cutter, and I'm blown away by how easy this was to repair. Thanks Sammy for helping me see the light
