So what is wrong at buck knives ???????????????
I can tell you what is wrong with at least two Buck's and I can tell you that one knife has been waranteed and the other should be. so here goes with the email I sent them
Edited version sent to the warranty email address
Steve Renovo
Mon 7/19/2021 6:39 PM
To The Owners and Staff Of Buck Knives:
RE: Order number: 896445
I purchased a Buck Momentum Pocket knife Directly from Buck and it arrived last week and I finally had some time to sharpen it last evening. Before I go on, I must say – BUCK did a great job on aesthetics, This knife looks awesome closed and even better when opened. The safety for keeping it closed is appreciated and the pocket clip for those that use them is great. The scales are nice and perhaps in the future BUCK will offer variations in scale material.
I also took time to remove the clip and to really examine what I hoped would be my favorite knife for at least a while. However, after doing more work than I wanted to expend it has become an Almost GREAT Knife and has joined the 30 or so other “Almost GREAT Knives” in my knife case of 50 plus knives. My “Almost GREAT Knives” sit in the case far more than they should and are seldom used. At 73 I have been buying a knife or two a year for probably 60 of those years. A few I lost, one was taken away, some became gifts and others are in my knife case with the best in the top drawer where they can be seen as there is a glass top. I had hoped this knife would be the first one I reached for most days – BUT…………..
These are my comments and while I do not have a camera to take good closeup pictures I will use words and as well as a phone picture or two to explain the flaws and improvements needed to make Momentum the GREAT knife that BUCK KNIVES made.
- The easy one – Buck like many makers put a pocket clip on it Momentum knife. I am one of those customers that does NOT like pocket clips. The clip came off easily BUT its absence leaves an ugly “slot’ in the butt end and two empty screw holes in the scale on the side. Had the holes in the liner been the same diameter and threaded as are the holes in the clip – that oversight would not be an issue – I could have just reinstalled the screws in the scale. Another solution which might have save some money wound be to NOT countersink the screw holes and then it would not look so bad in that area.
- The Ugly hole in the butt end. Another easy fix as well as a chance for a small sale – why didn’t BUCK make a small piece to fill that hole/void. Included it with the knife or sold as an accessory it would have shown great thought and concern for customer satisfaction. An even easier fix would have been not to have machined the end of the scale and just lengthened the tang of the clip slightly then there would only be the smaller unsightly cutout in the liner. I recognize that modifications and finish work and design concerns cost money but since I try to only buy quality products, I have noticed more and more that most American manufactures don’t always think of or execute the little things that make a tool a cut above.
- More seriously, as humans age lots of thing go wrong . One of these is that our skin thins so that sharp metal edges wear thru our thumbs and fingers and they get sore. So last knight I spent nearly an hour filing the wire edges of the left and right side of the thumb safety on my NEW Momentum knife. What would have been a few seconds attention to detail at the factory took me that long with miniature files BECAUSE I did not want to scratch the thin black coating on the scales. I got most of the wire edge but nevertheless my right thumb is irritated from the wire edge. Also the wire edge on the right side makes the safe a little less smooth when rotating the safety.
- If I had been able to buy the tool for both tightening and removing the pivot fastener my hour of careful filing would have been shorter by far. Why not make the tool available for those of us who are handy?
- The blade isn’t centered when closed – When in the blade is open it wiggles from side to side and when the blade is closed it moves around and looks sloppy when not centered. Something else to work on.
- The most annoying – while the S30V steel blade is of obvious high quality and if BUCK’s claims that its proprietary method of hardening/tempering are true I expect this blade to open lots of boxes and peel bunches of apples and cut wood splinters in my workshop for quite a while before it needs re-sharpening BUT then when I look at the miss ground tip that isn’t symmetrical I feel really sad and my Momentum by BUCK became an ALMOST GREAT KNIFE.
- The final disappointments were – a. I noticed that the action seems gritty BECAUSE it was – when I flushed it out with WD40 little bits of either abrasive or metal fillings came out of the right side of the pivot and so my new BUCK Momentum has those awful semicircular marks on the tang of that S30V blade that say someone did not care enough when the knife was assembled to wipe away the grit. And b. then I looked at the grind marks on the finished blade in angled light and I could see that there were three separate regions where the blade met the grinder/buffer and so the final finish was not uniform. A simpler solution would be stone washed. I love satin finishes when done correctly but stonewashed will do if satin can’t be done uniformly.
Finally, I wanted to really enjoy this knife – In addition to BUCK, I have Kershaw, Spiderco, Benchmade, CRKT, Booker, Victorinox, Bear & Son, Zero Tolerance, Camillus, Case and a few more but I always liked BUCK. The only knifes I gave as gifts were BUCK and I have never written to BUCK or any other knife maker before as I was never so disappointed in something I expected to be so nice from a manufacturer that I had grown to like over the years. But those were 110s and 112s and as BUCK moves into the making of knives for more modern collectors and aficionados as opposed to users like me - attention to these details is crucial. I never had to warrantee a BUCK Knife and since I sharpened this knife with my Wicked Edge sharpener it cuts well, it has joined the other Almost GREAT Knives in a lower drawer – maybe I’ll cut nails with it. Perhaps I should return it and you could take it apart and at least fix the blade problems.
Please let me know what you want me to do.
Also, I am not a social media person so I will not be posting anything negative - I thought it best to share my concerns and suggestions with the folks at BUCK.
Disappointed,
Sent from
Mail for Windows 10
And Then Buck's Reply:
Buck Knives Warranty Status
no_reply@buckknives.com
Wed 8/4/2021 9:00 AM
Dear STEVE RENOV, thank you for being a member of the Buck Knives Family!
Your package has been received by our Warranty department and will be processed promptly by our Warranty technicians.
Warranty Order Number: 01128519
Received: 08/03/2021
Warranty Determination:
REPLACEMENT
Warranty Description:
294BKS1-B - BROKEN BELT CLIP EYELETS- WARRANTY REPLACE WITH SAME MODEL 717-263-3031
Shipping to:
STEVE RENOV
Some Street
Pennsyltucky XXXXX
US
If you have any concerns about your order, please call us: (800) 326-2825, ext. 2.
Thank you,
Buck Knives Warranty Team
warranty@buckknives.com
They didn't even get the name right and a broken clip was not why I sent it back
Then I bought a Buck Vantage PRO #347 and it is the first knife that does not flip at all and even worse there are 4 screw protruding into the blade cavity and I can't see any bronze washers or enclosed bearing cartridges.
So Buying a third Buck "modern EDC" would be an example of what "W" said about fool me once..................................
