If the AEBL fighters turn out to be popular is there any consideration for HDFKs in AEBL. I’d love to have one that would be more salt water resistant
What is the max length and width of a knife blade you can produce
Is the DEK-1 on this years production schedule, mid-summer?
Sweet! As much as I like the FK 1 & 2 and the UF, the DEK sounds like it has the potential to be my Goldilocks pattern for a fixed blade.It's the next model. Development will start here this Spring with prototypes this summer. Real production may start as soon as this fall.
In theory probably about three feet total length with a blade grind width of perhaps 3". But using the fixturing and setup techniques we use the 18" total length, 12" blade length of the Behemoth is pushing the limits and the nearly 2" grind height on the comp choppers was challenging. The KOD piece will require a different manufacturing approach than we normally use.
I would suggest checking out REK (Razor Edge Knives). Josh does great work and can likely handle everything you are looking for.
Understood, thanks. A more general question, if you dont mind me asking- what does the process look like for becoming a high level machinist? Is there an apprenticeship period, or a mix of courses and practical application?I'm sorry we don't do custom work of that nature at this time.
Thanksfor the referral, I didnt know Josh worked on folders too. I will send him an emailI would suggest checking out REK (Razor Edge Knives). Josh does great work and can likely handle everything you are looking for.
Website: https://www.razoredgeknives.com/
Instagram: https://www.instagram.com/razoredgeknives/?hl=en
