Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
M390 and other steels with similar properties seem to be the go-to steel for premium folders.
What’s your thoughts on these steels compared to the Elmax, D2, and AEBL currently seen on CPK blades and does it have any place in a future CPK offering?
I’m also curious how much more performance you could get out of them than the current heat treats offer.
The Shiro I'm carrying uses M390. I think I had it in a Reate I lost too. It's not great. No better than the S30V in the Sebby I was carrying before that, and that didn't set a very high bar.
I have experimented with the alloy here and have done heat treat trials with it. I don't really like it. It's not bad, but it's not great. I suppose the abrasion resistance is very good as is the corrosion resistance, but it doesn't stay very sharp in real use as well as alternatives such as Elmax. I think there's just too much alloy and carbide for the matrix to properly support a knife edge. Mushy crumbly when I've used it.
I think one reason folks have mixed results with it is because, in my experiments, it was unusually sensitive to quench rate. The Rockwell hardness numbers they show in the data sheet are what I've seen in atmosphere quenches but my testing of the alloy here I got significantly higher numbers with faster quenches. This degree of sensitivity and the variation you will get from one setup to another and from one geometry to another means that the optimized heat treat for it may be illusive and inconsistent. Most volume makers waterjet, heat treat, then grind. That solid cutting edge area was thick during the quench, and it was a nitrogen gas quench in the oven which isn't real fast to start with, so I don't think they're always getting the quench rate that alloy needs. Not ideal for the alloy and would explain why it doesn't perform great in the factory knives I've used.
So, to me, I think it's probably an outstanding material for it's intended uses, but for cutlery I've seen better real world performance out of regular S35VN. People put too much credence in those card stock cut tests and perhaps knives with obtuse edges or subject to light use. I played with it and didn't get the edge stability I want and haven't messed with it again.
