Do you float or sink when in the ocean water?! Have you ever surfed? You have that hippie-beachy look, although a bit on the pale side
This may be a stupid question. Regarding the scales on your knives...Is there ever a reason to take them off for cleaning/oil/maintenance.
I put a thin coat of Obenaufs LP under the scales because whatever I put under there always seems to work itself out into my hands and I don’t want a petroleum based product coming on my hands when I’m out somewhere and can’t easily wash my hands with soap. I always seem to have food involved and I don’t want some gun oil or whatever on my hands.
It comes off easy enough when cleaning and the metal looks brand new after extended periods, including rinsing with hot soapy water. I think the wax in it keeps lots of water out, but not all. I do get spotting under there without a coating though, even with no water/rinsing involved.
Hot water to heat the steel up a bit, quick dry then rub a ton of Obenaufs all up under there. Like Justin said, it is food safe and the wax helps prevent moisture from working it's way in. I do this for all my field knives and have never had an issue. Long term storage of a knife this works very well if having it in a sheath
What's next on the Carothers docket of offerings?
Thank you, sir. I wouldn’t have thought to use it as a metal protectant, but I’m going to take your word for it and snag a jar.
Is this the stuff you gents are referring to?
Yes Sir. It’s outstanding.
never.truly.lost and I live fairly close to one another but he works in the forest for a large part of the year. I don’t.
I txt him with gear question as we have fairly similar taste and a lot of the same gear.
Anything he recommends has a passed a field test you can count on.
