ChazzyP
Platinum Member
- Dec 27, 2014
teddyashe
CPP
's method seems a good way to get a lot of heat to the pivot. As the Pero is CF both sides, if you're nervous about putting that material in direct contact with a high heat source (as I might be), you could find something like a steel nut to place under the pivot, shimming up the back of the knife as well to afford full metal-to-metal contact for good conductivity.
For my own part, I've had good luck with the hair dryer, leaving it on the male side for a loooong time to get it wicked hot, then pushing the knife down hard on a no-slip rubber pad while using the appropriate bit in a stout-handled driver. Like CPP says, when you get the thread-locker really cooked it doesn't take much force, but a bit of resistance won't hurt.
Edit: We seemed to be posting at the same time. Glad it worked out.
