- Aug 3, 2015
Hi,
Have you ever had a problem with the lock in your Shiro? I worry that after some time it will wear off and the knife will have bp. In models that have steel insert fixed on screw it should not be a problem, but what about f.e. F3 in which it seems to be pressed in? I know that knife can be sent to Russia, however, it can a bit complicated.
Are there any long time users here?
Even for inserts attached via screw, the knife will still need to be sent to Russia as each insert is fit to each blade individually. The workshop can remove inserts press fit and glued in such as on the F3 or NeOn and it is not more expensive to do so for them than a normal insert, so I would not worry when or if the time comes to do so.
