Following some tutorials here and other places- especially the advice given by Normark
I was able to get my first one work out fairly well.
You can search those threads out
In summary this has worked for me-
Masking taped 2 layers of thicknesses on the blade to allow clearance.
I used a toaster oven to do the first mould and a heat gun to fit the retention.
Blue sleeping bag foam from Wal-Mart – layered and glued together to get about 3- 4 inches of thickness per side.
Steel backing plates minimum 3/8 inch
I started with 3/4” plywood, but it flexed a lot and took me to the limit of my vise opening.
*** HEAVY PRESSURE ***
Now I admit to being way too close to 300 pounds, but some sort of mechanical advantage is a must to get tons of force.
You have to clamp it tight and keep it there until the kydex cools enough to lose its elasticity.
I think heavy pressure and enough heat will solve your problem.
I don’t know how standing on it became the recommended SOP, but I think it’s so easy to better that.
Skip the hinged waffle iron press – like you see in knife kits.com. It causes the material to slip sideways with the uneven pressure.
Others have used c clamps and hydraulic presses.
I tried the c clamps, but juggled and dropped them a lot. It was cool before i was done.
I found using the mechanics bench vise I already had worked pretty well. It applied tons of pressure very fast with no movement of the materials.
If I did more that way, I would mount a vise with the screw vertically.
Use a spray lube as a mould release, like “Pam” no-stick cooking spray.
Once I was done, the impression of the knife was imprinted in the foam. It can be reused with a different knife, or just kept aside for the next time you do the same knife.
The best foam???
I’m sure that there are better, but it would be a trade off of $ vs., durability.
High production methods use vacuum moulding around a standardized form.
Attached is the photo of the first one I did using this method - I was happy with the results.
Note the difference between Bruce's photo and mine.
I did a fold over at the top with a rod in the tip to allow a drainage hole for cleaning.
Bruce used two seperate layers. He achieved a much nicer finish along the blade spine using this method
