- Dec 27, 2014
Ugh.. You're not making this any easier on me VolGrad!
I've never been a fan of sheepsfoot or wharncliffe type blades, but the look is a little more tolerable for me on the Insingo. I was wondering what people like about them compared to the clip point in use (not really looks or that they're less threatening). What tasks do you find easier with the Insingo blade? I've always liked a tip and belly in my knives, but I see a lot of praise for the Insingo for actual EDC use. I'm pretty sure my next Sebenza will be a small micarta, but I was thinking about throwing in a little variety and possibly getting it in the Insingo version as both my 21s are clip points.
Great post. Thanks for the info. If I had to choose today, I'd probably go clip but it is one of the better looking sheepsfoot styles out there. Wharncliffes such as the Hinderer variety and the Yojimbo just look like box cutters to me.I dont have an Insingo either, but I have carried several modified wharncliffes (MW) for years and feel that I can offer something here. Essentially the blade shape will easily do anything a clip can do except for belly related activities (like skinning). Im not saying that you cannot skin with it, but the whole bennefit of the lower point is the sharp transition at the point and its relative angle to the wrist in the neutral position. This makes the MW exceptional for cutting holes in things in that you need not lift your elbow much to achieve the angle that puts the transition point (tip/spine) in proper alignment to pierce without stabbing.
(wow that might be hard to read...try this to clarify....hang a sheet of paper and try to slash through it with your clip point. Notice how it gets easier if you put the tip of the knife in the lead as you slash? Where does your elbow/wrist go to acomplish this? You can do the same thing with a MW without needing to do that odd movement...you only will need to flick your wrist)
Imagine cutting a coupon out of the middle of a newspaper page (without cutting the rest of the page). You need not raise your elbow as much. The same reason (ease of piercing with slash-type cuts) is why the blade shape is NOT desirable for skinning (because you generally do not want to pierce or slash the hyde.
All the other tasks I do, generally involve cutting that is done equally well with MW or drop points...so, yes, the difference really is not a matter of "better at everything". It is really a matter of better at a couple things, the same at most things, and not as good at a couple things.
Another bennefit of a MW is you effectively have more flat edge than a more bellied design. So, if you are doubling over rope and cutting it all day long, and can only have a blade X inches long, a MW will offer you more edge to do the cutting before you slip up the belly (where your edge is not perpendicular to the cut direction) and off the tip.
Is it right for you? Ill suggest that you will never really know til you try. Some like the looks, some like the performance, some like both. Regardless both are subjective to the user and his/her uses
I dont have an Insingo either, but I have carried several modified wharncliffes (MW) for years and feel that I can offer something here. Essentially the blade shape will easily do anything a clip can do except for belly related activities (like skinning). ...........Is it right for you? Ill suggest that you will never really know til you try. Some like the looks, some like the performance, some like both. Regardless both are subjective to the user and his/her uses
