The Fällkniven U2 Folder…
By the numbers:
Length Closed: 3.85" (86mm)
Blade Length: 2.52" (64 mm)
Blade Thickness: .098" (2.5 mm)
Weight: 42 g (1.5 oz)
Steel: Laminated Super Gold Powder Steel
Hardness: 62 HRC
Handle Material: Zytel
Locking Mechanism: Lockback
Features: Ambidextrous Nail-Nick(s), Lanyard Hole
If you do your homework and research the Fällkniven U2, you will find quite a bit of controversy over this little guy. Why? Mostly because it ain’t cheap; especially for a small-sized folder. I took a quick tour online and found the average price to be around $100 for a “New In Box” U2. With so many great options available in the sub $100 range these days, it’s easy to understand why many folks might feel a little ‘underwhelmed’ upon first inspection of a Fällkniven U2: all you get out of the box is a 2.5” FFG stainless steel blade with a common lockback mechanism and plain-looking plastic scales.
So why is the U2 so expensive? I have no definitive answer, but I can surmise that the cost is attributed to two factors: country of origin and blade steel. The Fällkniven U2 is a Swedish design manufactured in Japan. We often hear about our European counterparts paying a premium for their knives and the U2 is no exception. Whenever the manufacturer’s cost goes up, the price for the end-user will also increase--it’s just that simple. We North Americans can then expect to pay an additional cost for an imported product. Again, this is just my best guess as I am not privy to the inner mechanics of the Fällkniven business model.
Well, I’m not much of a steel guru, but let’s discuss this Super Gold Powder Steel. What is it? I did my best to research this steel and found little scraps of information here and there (*disclaimer: I felt like Carlyle's editor in Sartor Resartus-- http://www.allreaders.com/topics/info_25502.asp.) From what I read, SGPS is simply the proprietary name given to Fällkniven’s laminated steel. Laminated, San Mai, damascus, or even composite steel blades are more expensive to produce. When considering these factors, the price of the U2 does not seem quite so outrageous—perhaps one might even view the U2 as a ‘budget’ folder to the laminated steel class.
The biggest criticism I have of the U2 is the limp warranty. Right off the snap, the box states: “Limited two year warranty.” Really? Come on, Fällkniven! I’ve spent far less on knives that have a “Forever Warranty” (I’m looking at you, Buck Knives :thumbup:) This was a great disappointment to me, as I had expected a far better warranty from Fällkniven (especially at this price-point.) Whenever I see a lifetime warranty, whether I have occasion to use it or not, I’m lead to believe the manufacturer has full confidence in their product. This, in turn, makes me feel a little better about my purchasing decision.
I think a lot of folks won’t care for the liner-less Zytel handle on the U2, but I don’t mind it. It has a very slight texture to it; similar to the Spyderco Centofante 3 but perhaps just a shade rougher. I would have liked to see some sort of shield or inlay on the handle to dress it up a little, but there is still something very classy and demure about the unadorned clean approach—elegance in simplicity, I suppose. I think a polished G-10 handle would have been the cat’s pyjamas, but since I regard the U2 (and smaller U4) as an entry level Fällkniven folder, I can overlook this. Fällkniven does make higher-end folders that use premium scale/handle material (wood, bone, pearl, micarta)… at added expense, of course (for reference: their TK3 and FH9 models fall within the $200-$300+ price range.)
The pivot has no bushings or washers as far as I can tell (I’ve no plans to take the knife apart to tell for certain,) but the blade has a nice smooth deployment. I like the lanyard hole (no problem getting 550 paracord through it) and I think if one wanted to dress up the knife a little for a more ‘gentlemanly’ appearance, a nice leather lanyard with some kind of polished beads could do the trick. It isn’t a hard-use workhorse type knife; think of it more as a high-quality and understated EDC: people-friendly, light, and sharp as hell. The closest competitor to the Fällkniven U2, in my opinion, is the FRN Spyderco Dragonfly 2. Other affordable alternatives include: the Buck 55, Buck Vantage Small, and perhaps the CRKT Drifter.
Overall, I am pleased with my Fällkniven U2. I feel the cost was justified, although the jury is still out on the capabilities of the steel—time will tell.
Anyway,thanks for reading! :)
-Timber
ETA: I have sent Eric of Fällkniven knives a message regarding SGPS and will make any corrections regarding the U2's steel based on his feedback... :)
I have a U2, bought several years ago. The one thing that bugs me about it is that the edge of the blade makes contact with the lock bar spring when closed. It actually put a nick in the spring, although with the hardness of the blade steel I haven't noticed any damage to the edge. The two samples at my local dealer showed the same problem. I think this kind of thing should have been taken care of in the design process.
Thanks for the input, Kyle! Could you post a pic of your U2? I know it might be tough to capture a shot of the lock-bar damage, but I'd like to keep an eye out for any signs of the same issue with mine...
The U2 is a dandy little pocket knife and a beautiful and simple gentleman's folder.
The blade reminds me of a shorter, smaller but stronger Boker Plus Exskelibur series.
The comparison with the Dragonfly 2 FRN is a good one, although in price, the U2 is more comparable to the D'Fly ZDP. I slightly prefer the D'Fly with its Spydie hole and wire clip.
The U2 couldn't be more simple, and I have had no issues with the blade, lockbar or spring. Highly recommended if you are willing to spend the $$.
From what I read, SGPS is simply the proprietary name given to Fällkniven’s laminated steel which most likely* (*I could be dead wrong on this) uses VG-1 (sort of like Cold Steel’s San Mai.) VG-1, also called V Gold 1, is a powdered steel made by Takefu Special Steel Co.,Ltd.--the same Japanese company that makes SGPS for Fällkniven.
You are dead wrong.
VG-1 is a melt alloy, not powder steel, so it is not the center. And with a Carbon content of ~1%, it would not make a good outer layer for a laminated blade. Can't be any VG-1 in those blades.
http://www.e-tokko.com/eng_vg1.htm
It might be noted that VG-1, which has indeed been used by Cold Steel, has an edge retention on the order of that of the better known VG-10. VG-10 is supposed to be tougher and more corrosion resistant that VG-1.
"SVGS" is made by the same company, e-tokko. And it is made by a powder metal process. There is not a separate data sheet for it, but it is listed as "Super G1" at the bottom of the table on this page:
http://www.e-tokko.com/eng_original_list.htm
The cladding is likely an alloy similar to 420 (not 420HC).
Had the same issue, ground off the edge with a belt sander and resharpened it so the blade was narrow enough to not hit the lock.
I can't recall the source, but I heard or read somewhere that the outer layers are 420J2. How true that is, I don't know. I do know that the outer layers on my U2 scratched more easily than any other knife I've handled, suggesting that they're pretty darn soft.
I like the U2 but can not justify shelling out the cost of one. There are far too many quality alternatives at a lower price point. I don't understand the argument that country of origin is responsible for the cost. After all Spyderco knives are manufactured in Japan as well.
You are dead wrong.
Thanks for the info, Frank. I've edited the OP. :foot:
Cheers!
I have the U2 and the TK4. The TK4 has a similar design, but is larger with a 70mm blade. Even though both are supposedly the same steel in the core of the laminate, my
TK4 holds a sharp edge very well, but I can't say the same for the U2. When I got the TK4, it was about $95 and the U2 was $70. Prices
have gone up quite a bit since then.
The TK4 is a utiliarian version of the TK3 and a much nicer knife than the U2 - in my opinion.
When the Dollar to Euro was better, my U2 cost $60
A small delightfully designed gentleman's folder in the minimalism of Scandinavia
The steel is amazing
It is scary sharp, and in all the time I have had it, I have only stropped it
The knife is very light and thin
I have put a cell phone strap thru the lanyard hole, and it makes for easy retrival from my pocket
The double sided nick makes for a very easy pinch opening
And it locks solidly
The back lock is easy to use and closed well
You pay for what you get
Well worth it
About the varanty 2 years is a swedish standard. I have a few fallknivens and Peter helped me with my first U2 s pivot screw after about 9 years so he stands behind his produkt the way most swedish manufakturs of good tools do, for à long period if used right.
Steel specs
C 1,4
cr 15
Si 0,5
mn 0,4
p 0,03
mo 2,8
s 0,03
v 2,0
Hardness 62 hrc
outer layer 420j2.
(From fallknivens homepage about SGPS)
Bosse
So here I got a little more time to write.
I have a long history with bying knifes from the fallkniven company. They started out selling high quality brands as gerber, puma, schrade, spyderco etc. Most of the good companies of those times. After that they started selling their own products and at the time I bought my U2 folder I had been waiting for years for them to produse a EDC folder. I know it was autumn 2003 since my boy (then a baby) was with me.
I have yeat another U2 that I bought last spring.
Im mostly into carbon steel, bone handle slipjoints nowadays but if I use another knife its a U2 or Delica. For me its a simularity about stainless and FRN, sort of a bound, a thought that runs through the knife about materials that is modern and dont need maintainance.
I hunt and fish a lot and I like how easy this knife is to keep clean. Much easyer than the delica as it has holes in the inner metall frame. The U2 is very simple and flat inside. I find this knife to bee very related to the FRN Gerber LST (An old favorite of mine) but yet better in every aspect.
My example has stood up to hard work. It has started its fare share of camp fires and cleaned bouth fish and birds.
When it was new I once took it as my only knife to moosehunt and that particular day ended with two big moose bulls. I remember the U2 to be still fairly sharp afterwards. The moosehunt season is still the times when I most regularly carry my U2 as EDC despite my love for the slipjoints. This is because I sometimes stumble upon more extensive cutting than expected.
I find my U2 knifes to hold a good edge and also to sharpen up again easy with diamonds and cheramic.
Knife pricing is a jungle. Here in sweden a Gerber LST costs 400 SEK a U2 costs 800 SEK and a delica 1000 SEK. A normal slipjoint is almost impossible to by here but as an example a Buck 301 is the same as a U2 a case sodbuster the same as a LST and a case medium stockman more expensive than 1000 SEK. For comparison with another european brand a Alox SAK electrician costs me 300 SEK and a red classic 150 SEK.
1 $ = 6.75 SEK.
All and all I find my U2s to be exelent knifes and If it was my only one I could be glad having souch a good EDC.
None of mine has the problem with the edge touching the lockbar. As the knifes are hard in the steel I dont find them suited for non knife people, they are probably most often better off with a LST or SAK.
Thank you for contributing, NirreBosse! You've added some very useful info; I didn't realise that a two-year warranty was standard in Sweden. Good to hear the company still took care of you long after their written obligation had expired... :thumbup:
I still use and enjoy my U2. It's a very nice little knife that has become one of my favourites!
